motor exploder
Got the cab on, now what? Experienced Frame-Off gurus step inside...
Got my cab set down on the frame this weekend, now I'm trying to plan my next steps. I have been looking at MANY of the build threads to see how/what/when others are doing things, but I figured I'd post it up for discussion. I have all the parts already - wiring kit, interior pieces and all the underhood stuff.
My plan was to lay down the Dynamat inside the cab, then mount the brake & clutch master cylinders on the firewall, plumb the hydraulics (brakes/steering) under the hood then jump back inside and install the wiring harness inside, wire the engine and finish out the interior. Then install the fenders, hood and doors. I just want to go in an order where I'm not fighting myself having to take stuff back apart due to doing things out of order. There is a pile of parts sitting in my garage so it's hard to resist the urge to just start bolting crap on just to see what it looks like. I want to be more efficient at this stage in the project so I can be driving this thing come spring of 2015.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 12-01-2014 at 03:18 AM. |
Re: Got the cab on, now what? Experienced Frame-Off gurus step inside...
D@mn that trucks pretty
Jack Personal Fleet: Family Fleet: 1955.5 Panel 1959 Apache 1968 ShortWide 1969 ShortStep |
motor exploder
PPG Deltron 'Tungsten Metallic'.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
I think I found the color of the 67 Camaro..... Lookin good man.
motor exploder
here's a pic with some sun on it. As for the core support, it's stock, but I took a couple hole saws and some dimple dies to it.
I'm sure everyone has a different way to do it. When Mine was at the place yours is I started by putting the doors on, then put all the glass back in it followed by the everything on the inside i.e. Steering column gage cluster etc. then sent it over to have the wiring put in it.
1967 swb 454 cid 700R4 trans SOLD 2006 Chevy Trailblazer SS 2013 Camaro RS convertible the wife's Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248 |
The steps i use are as follow. Interior- put everything that can be chunked, Heater ducts etc. together before hand . Start at the dash pad and work down and out. From pad do the wiring and then radio and heater. Run ducting and dash cluster. From there glove box and column and emergency brake assembly. From there install carpet dome light seat belts and then gas tank. Install seat then doors and and window regulators. Install glass loosely and then install vent windows, followed by weather striping. On engine bay run engine harness across firewall and hook up starter etc. Install outside heater box if not already complete with interior stuff. Run headlight harness and hook up at core support. Install inner fenders next- the cab will square core support via the inner fenders. Install all of this loosely. Install outer fenders based off of doors and adjust as needed. Install hood latch, hood hinges and grill. Install front bumper. Front assembly should be complete or very close from this point. Hope this helps.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
#9 | |
![]() Join Date: Apr 2008
Wow she is SEXY!
Too bad you have to "finish it" and can't drive it like that! |
Divorced .....WITH KIDS
What size rear tires and brand ?
1969 GMC SWB 1975 Chevy Malibu 80k 1963 Ford Galaxie 63k (inherited) 2005 Nissan Armada (wife's idea) |
#12 | |||
motor exploder
Thank you - matte clear on the interior & underhood. The outside and door jambs are gloss. BF Goodrich KDW 335/35/18
damn, shes gonna be a beautiful girl.. nice color choice!
One question with the smoothed firewall, what are the 4 tubes sticking out? Is that heat and air hookups? What suspension did you use? Ok that was two questions...
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
#14 | |
motor exploder
Here's a better pic of the paint color on outside of the body.
#15 |
![]() Join Date: Apr 2014
Very nice man! Keep the progress pics coming
#16 |
71 Super, great info on putting the truck back together. I'm hoping to be ready to put things back together this spring and I'll bookmark this page for sure! Great question Boss. That color and smoothed firewall look great!
1967 GMC 1500 SWB. Driving this truck since I was 14. |
#17 |
![]() Join Date: Sep 2007
And i ALMOST went with that color too but the orange grew on me... well that and my og firewall paint polished up real pretty.
Did you customize the rad support or buy it like that?
1967custom |
