Old 12-02-2014, 12:13 AM   #1
buds56
buds56's Avatar
eaton rear reliability
I've started on a 61 apache 10 shortbed.
My plan is for a mild 350 with a 400 turbo,
Hoping to keep the torsion bar suspension with an upgrade to PS and an addition of a sway bar and a disc conversion.
My question is one for the rear axle. Its a 3.90 ratio, which I like.
I see there are seals, bearings and brake parts available from NAPA.
I'm curious if most people switch them out looking for a more highway friendly gear or are they unreliable.
Thanks, Bud
buds56 is offline   Reply With Quote
Old 12-02-2014, 12:42 AM   #2
j.kirn
Re: eaton rear reliability
eaton rearends are very reliable
j.kirn is offline   Reply With Quote
Old 12-02-2014, 08:59 AM   #3
Clyde65
Clyde65's Avatar
You have an HO33 probably, it is a 10 bolt and worked in 60-62, they were and are very reliable, however getting repair parts are no fun. IIRC They have like two ratios available.
If you want a more highway friendly rear and want to keep the 6 lug, you can go with any truck 12 bolt. You will need to cut off and reweld the trailing arm mounts though. Nothing is a bolt in other than another HO33. if a posi is what you want, they are not available, and gears are high too!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-02-2014, 10:51 AM   #4
verdell
verdell's Avatar
I switched the original rear from my '60 to a 12 bolt with 3.07s from a '65. Relocated the mounts and bolted it back on. I did it for better highway cruising and its great but looking to switch to 3.42s in the near future.
verdell is offline   Reply With Quote
Old 12-02-2014, 02:43 PM   #5
61K10
61K10's Avatar
the eaton 32/33 was in 1955-62 1/2 ton tks. only one ring & pinion available 3.38 the 3.90 is not made any more (sadly) the bearings/spider gears/seal are the same as 1955-64 car. I am putting new bearings in one i just bought. hope it's quiet. Might take my org one and install the 3.38's but being 4wd that screws my ft axle up as it has 3.92's and the closest to 3.38 is 3.31 for the dana 44 which would be pushing it bunch. could run different tire sizes?? just trying to stay original.
now a hot-rod type tk i would go 12B or ford 9"
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
