Old 12-06-2014, 11:39 AM   #1
72chevycamshaft
69 gmc dually soon to be 12valve
Starting the build....swapped out the old eaton ho52 with a dana 60 front. Found a guy the had the military front end and rear. That made life awesome....the leaf springs are shot on the rear on this truck......I'm toying w keeping the air compressor on the motor (motor is out of a commercial truck). Anybody have suggestions for air ride for this project? Ive seen a few posts with guys on here going that route. The truck had and eby flat bed on it and I'm still undecided if I'm going to keep it. I'm planning on using this truck when I'm done. I haven't put new pair of springs order a one ton in years....I can only guess with what that cost will be.
72chevycamshaft is offline   Reply With Quote
Old 12-07-2014, 06:43 PM   #2
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: 69 gmc dually soon to be 12valve
Sounds like a good project! You could keep the leafs and put on assist bags like Air Lift. I have Air lift bags on the rear of my 12 valve K30 truck.
Oh, and we needs pics!!
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 12-08-2014, 03:55 PM   #3
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
If you want to ditch the leaf springs all together, I'd go with a 4 link with a pan hard bar. You say you ditched the Eaton for a D60 front? Are you going for a buggy or truggy out come?
Ryan
1969 Chevy milk truck
Old 12-09-2014, 03:19 PM   #4
72chevycamshaft
Little confused with the Truggy comment. The eaton front has drum brakes and is the old jeep style axle. Don't know the correct name for it. The steering linkage was also problematic for the cummins swap. The steering linkage just cleared the pan of the 350 that was originally in the truck.
Old 12-09-2014, 03:42 PM   #5
Dieselwrencher
I think I see where I was confused now. You said in this post the eaton front. Unless your truck was a napco conversion, it had a D44 with closed knuckles and drum brakes. When I read your original post, I read it as you were using a D60 front in the rear. The only reasoning I came up with was a truggy. Haha Any way, carry on.
Ryan
Old 12-09-2014, 03:40 PM   #6
Dieselwrencher
The part in bold is what I was commenting about. An HO52 is a rear end. You said you swapped the HO52 with a dana 60 front. Then you say you found a guy with a military front and rear end. By military front end, do you mean chevy D60 and 14 bolt? Just trying to see what you have going on is all. Sounds like a cool build.
Ryan
Old 12-09-2014, 03:45 PM   #7
72chevycamshaft
My bad....took me awhile to figure out what types of axles I had under the 69. I assumed that they would both be the same with the eatons. If it's not and ho52 for the front than would could it be? From the pics I've seen online with the bolt patterns and shape of the pumpkins they sure look like eatons. This truck originally was a brush truck for a fire company....the whole drive train looks like a conversion. What do you mean napco conversion? Anyways....military d60 for the front and 14bolt locker for the rear. Lol
Old 12-09-2014, 05:18 PM   #8
Vintage Windmills
Vintage 4x4s
I'm betting this was a Napco or Marmon. Look for badges or labels Napco or MarmonHarrington. You couldn't get a dually 4x4 until 73 from GM. The Napco stuff is worth more than scrap FYI.
Old 12-09-2014, 06:25 PM   #9
72chevycamshaft
It has the works....divorced transfer case pto winch to the front.......least it did. Maybe I should have left it together lol! Ill look and see if I can find any tags....I just figured the fd had put it together.
Old 12-10-2014, 11:14 AM   #10
Dieselwrencher
Post up some pics and we can help you identify them. Sounds like it very well could be a converted truck.
Ryan
Old 12-10-2014, 07:51 PM   #11
72chevycamshaft
What's the trick to posting pics....do I need to take them from the phone to photobucket? I tried copying and pasting.
Old 12-10-2014, 08:15 PM   #12
Dieselwrencher
I usually upload them to photobucket. Then I have to resize them to 640x480. Copy and paste the image code in your message, not the direct link. Photobucket can be a PITA some times though.
Ryan
Old 12-11-2014, 09:39 AM   #13
72chevycamshaft
Old 12-11-2014, 09:41 AM   #14
72chevycamshaft
Old 12-11-2014, 09:43 AM   #15
72chevycamshaft
There's the front and rears out of the 69 brush truck. I should back up and start at the beginning with this build :-)
Old 12-14-2014, 07:03 AM   #16
brimc
brimc's Avatar
Please do !
Very interested to see more. Looks great. What's your plan for the drive train swap?
BRIAN
1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater.
My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509
brimc is offline   Reply With Quote
Old 12-11-2014, 05:35 PM   #17
Dieselwrencher
Well, you're correct, definitely looks like an eaton front. I bet that stuff is worth quite a chunk. I'd bet Jud can tell ya a decent market price on that.
Ryan
Old 12-11-2014, 06:03 PM   #18
72chevycamshaft
Yeah I'd like to know.....i stopped keeping track of expenses.... :-) I'll start putting pics up from when I started.
Old 12-12-2014, 12:25 AM   #19
72MARIO
72MARIO's Avatar
NAPCO ! That's a really rare conversion. The steering linkage would have been the 2 wd center link. As cool of a truck as they are the truck your builing will be much more practial. I was looking at doing the same thing to a 67 C30 but decided to just convert a longhorn frame to a Cummins. I can't wait to see your build progress
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 12-12-2014, 12:40 AM   #20
72chevycamshaft
Old 12-12-2014, 12:44 AM   #21
72chevycamshaft
This is the day I drove the brush truck home.
Old 12-13-2014, 11:33 PM   #22
6BT 56
6BT 56's Avatar
That's a cool truck. Sure looks like napco stuff. I hate to see that kind of stuff get taken apart but really it's pointless to build a truck unless you can enjoy driving it . My 56 had all napco parts under it and it was no fun to drive at all. I now have a D60 D 70 combo under mine with the cummins and its like nite and day . Runs good. Stops good power steering and actually is good on fuel as well. Also can get pars anywhere now . I sold my napco front and rear, the trans and the t/c for $ 2500. Keep I mind the only rare parts were the front doff and the t/c. The rest was the normal stock stuff. I like where your,going here will be following along for sure .
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 12-13-2014, 11:36 PM   #23
6BT 56
6BT 56's Avatar
Is that your farm ? Cool silo in the background. They don't build em like that any more .
Old 12-14-2014, 02:13 PM   #24
72chevycamshaft
Yup one of them. The tile silos are rare I agree.....yeah might have considered not tearing into a napco if I had known. Oh well...still going to move forward. I have a rebuilt nv4500 and tweaked the 241 transfer case to give me a right side drop. That might be a little problematic for my exhaust, but I'm confident I can work my way around it.
Old 12-14-2014, 02:21 PM   #25
72chevycamshaft
New cab corners and new inner cowl.
