12-06-2014, 02:32 PM | #1 |
67-72 Column wiring
Curious how people doing this swap are tackling the wiring?
Also, what is the electrical box with 3 pins towards the bottom of the column? I was hoping to just swap all the guts and turn signal switch from my '65 column to the '72 column, but it's totally different. Thanks! |
12-06-2014, 02:36 PM | #2 |
Re: 67-72 Column wiring
Looks like I can just put a 67-69 turn signal switch in it? Looks to be the same connectors as the pre 67.
Edit: Nevermind. Looks like it changed in 67. I'm half tempted just to cut the connectors off my new '65 switch and splice the wires, but I'm hoping there is another way. |
12-06-2014, 06:14 PM | #3 |
TILT COLUMN GURU
There are adapter harnesses available. The truck shop has them in stock.
http://truckandcarshop.com/trucks60_72/t60_064.html
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
12-06-2014, 08:30 PM | #4 |
I changed all of the wiring out myself. I could not see spending $35 on an adapter harness. I put female spade connectors on the cab wiring, and male spade connectors on the '72 column wires, and played with the wires until I had it all working properly.
I do not have the hazards working though, if you want them, it may be worth it to pay for the wiring kit, I think the flashers come with it. I figure it cost me about $1.00 in connectors, and 30 to 40 minutes time. Jim |
12-06-2014, 09:03 PM | #5 |
ALSO,
To answer your other question about the 3 terminals at the bottom of the column, that is the neutral safety switch. Jim |
