12-09-2014, 01:05 PM | #1 |
Door panel part's
I am cutting this door for panel repair's . If any one need's top section for top chopping ,ect, or a radio speaker repair ,here ya go. This is a driver's side door . I can cut more piece's if any interest in other area's. top section window frame $30.00 and radio repair panel full lenght $45.00 would do both door's if using short panel for hole's plus shipping.
12-09-2014, 01:12 PM | #2 |
Re: Door panel part's
The latch jam section section is sold for a customer. If any one need the nut insert's i can cut those out too , beyond nut area. Make a offer on these plus shipping.I can get another set of salvage door's if any more panel's are needed
12-09-2014, 10:12 PM | #3 |
I'm interested in 5 of the nut holders that hold the inner door panel on. What do you want for them?
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
12-09-2014, 11:02 PM | #4 |
How about 5.00 since i would probably burn up a cut off wheel plus shipping , but if you don't like that make offer. Do you want me to cut about an inch or so on all side's of the caged nut , and you separate????? I might be able to insert a screw and brake them loose from the door panel also would that work for you?????
12-10-2014, 05:04 PM | #5 |
PDX I was able to remove easily with a screw inserted in them and wiggling back and forth .if still interested let me know i have 12 of them.
12-10-2014, 09:20 PM | #6 |
Do you have any of the original screws that hold the door panel on? I could use some I'm missing a few.
Thanks, Matt
It only has original paint once |
12-10-2014, 10:10 PM | #7 |
yes i do .
12-11-2014, 05:06 AM | #8 | |
12-11-2014, 11:42 AM | #9 |
Sent you pm
