Old 12-12-2014, 04:19 PM   #1
Hampshire
Hampshire's Avatar
Hydraulic clutch setup - slave cylinder vs hyd throwout bearing
I have a TKO 5spd going behind a mild 350 in a 1949 AD. The guy doing the work has been building hydraulic clutch set-ups in vintage trace cars & has me interested. When sourcing parts, I didn't like what I was seeing/hearing about regarding leaks & failures with hydraulic throwout bearings - especially when a repair often means removing the tranny.
..so, when I started hearing about people using an external slave instead - I got real interested. When I used to fix imported crates during my college days, I removed/replaced/rebuilt many an external slave.
Ease of maintenance & no $$$ hyd. throwout bearing has it's appeal -
opinions?
Experience?
Fitment problems with an under the frame power booster already in place?
Let me know....
Hampshire is offline   Reply With Quote
Old 12-12-2014, 05:23 PM   #2
focusedontheprize
focusedontheprize's Avatar
Re: Hydraulic clutch setup - slave cylinder vs hyd throwout bearing
I am running a 292 in my '49 with a T5 behind it. I end up putting an external slave cylinder on it and really like it a lot. I really did my research on the hydraulic throw-out bearing setup, but like you my biggest issue is having to remove the transmission if a leak was to occur.
So overall, I am a +1 for the hydraulic external slave setup.
focusedontheprize is offline   Reply With Quote
Old 12-13-2014, 12:12 PM   #3
Hampshire
Hampshire's Avatar
That's good to hear - after going over it with my guy & showing him some pics, he's all for it. Just have to work out the new crossmember with the space we have left.
Old 12-14-2014, 12:27 AM   #4
roger55
roger55's Avatar
I've got a Ram Clutches brand hydraulic throwout in my '55 Bel Air and a T56 Magnum.
It was easy to set up and very clean without having to mount a slave.
5K trouble-free miles on it so far.
roger55 is offline   Reply With Quote
