![]() Join Date: Nov 2011
custom suspension 58 apache
Could any of you 4x4 guys take a look at this suspension set-up and tell me if you see any problems or concerns. This truck is being built for road use only.
1955 2nd on 86 chassis Daily driver |
Re: custom suspension 58 apache
By far an expert, but looks like both front and rear arms are too short. Won't get much axle movement up and down....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
im no expert either but it looks functional for road use only, the front reminds me of a newer ford e-450
It should ride ok depending spring rates in those coilovers.If you want it to ride like a caddy longer arms and longer coilovers.
Might want to think about some bracing on those rear coilover mounts and I'll agree with the others...arms are way too short.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF |
Thanks for the feed back. Will see what can be done with arms and coil mount.
On some jeeps the stock front arms are that short.Its a street truck it should be fine that short.How long are the coilovers and how much total travel do you have?
I believe they are 17 inch coils and are set for 3-4 inches of travel.
on road only it should be ok. not much travel with coilovers. Like Redcap says beef up the coil mounts.
1961 chevy K10 my build is------------61K10 build |
