Old 12-13-2014, 09:29 AM   #1
ozkiwi
lower my square 2 inches front and rear?
Fitted these 17 inch wheels 8 inch wide front 9 inch rear running 235/60 and 275/55 and now want to drop it down 2 inches both ends.Not much of a drop but thats all I want.
How can I lower the rear 2 inches ?Seems like lowering less than 4 inches is
difficult as all the kits I can find are for 4 inches?
ozkiwi is offline   Reply With Quote
Old 12-13-2014, 09:32 AM   #2
Jake Wade
Jake Wade's Avatar
Re: lower my square 2 inches front and rear?
What wheels are those? You can buy just shackles to lower the rear 2"
Jake Wade is offline   Reply With Quote
Old 01-02-2015, 05:31 PM   #3
Malo83
Cruzzzn' Vet
Malo83's Avatar
17-18" Rallys
http://www.ebay.com/itm/17x8-17x9-AL...81513892&rt=nc
Malo83 is offline   Reply With Quote
Old 12-13-2014, 10:18 AM   #4
Rich84
Rich84's Avatar
Beautiful truck...
Now get it out of the nose bleed section.Lol
Rich84 is offline   Reply With Quote
Old 12-13-2014, 10:50 AM   #5
badchevy
You can cut one full coil up front and put drop shackles out back. Only thing you have to notch the bed support to clear the longer shackle. If you don't want to cut the coils up front, you can buy drop springs.
badchevy is offline   Reply With Quote
Old 12-13-2014, 05:12 PM   #6
ozkiwi
Is cutting the front springs ok or is it better to fit new ones and I guess there is enough travel in the shocks to allow for a 2 inch drop without a change?
Not sure what make the wheels are.Saw them on a corvette outside the tire shop and just told them to fit a set of those.Some sort of alloy rally replica.
I do know I had my 15 inch Gragars balanced twice trying to get rid of front end shake and was told they were good.But with the new wheels and tires it now it rides as smooth as my wife's car at any speed.
Old 12-13-2014, 05:16 PM   #7
tinydb84
tinydb84's Avatar
I prefer drop spindles. Drop hangers will get you 2 inches and not have to notch the bed. They will improve your anti squat a little bit too.
David
Instagram: myfabguy
Old 12-13-2014, 11:33 PM   #8
MikeB
MikeB's Avatar
Being new to square bodies, I don't know what you mean by "drop hangers". Got any pics of these as well as shackles?
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 12-14-2014, 01:22 AM   #9
tinydb84
tinydb84's Avatar
http://www.summitracing.com/search/p...olet/model/c10
The top are the hangers the bottom are the shackles.
David
Instagram: myfabguy
Old 01-01-2015, 01:39 PM   #10
MikeB
MikeB's Avatar
Thanks for the info.
Are the stock hangers riveted to the frame? Can they be replaced without removing the bed? I'd go check it out myself, but my truck is outside where it's 34 degrees and raining!
Also, sounds like I'd have to notch a bed support.
What mods need to be done if I want only 2" drop in rear?
Mike
Old 01-02-2015, 12:31 AM   #11
bbbc10
Diggin The SquareLife
check ur inbox sir!!! its not that hard to notch the bed support at all an it doesn't make anything weak etc an yes the hangers are riveted to them frame an all can be removed with bed on
bbbc10 is offline   Reply With Quote
Old 01-02-2015, 01:12 AM   #12
UKNOWME
UKNOWME's Avatar
I promise you will want to go lower than 2".
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 01-02-2015, 07:46 AM   #13
Jake Wade
Jake Wade's Avatar
Yep
