12-14-2014, 12:07 PM | #1 |
ls1 harness how to protect the wires
Hy all
GM is originally using a corrugated tube for protecting the wires. Sorry but i am not sure how u call it in english.....i mean those black flexibel plastice tubes... My english translater calls it "corrugated tube" So after i have stripped the harness....i want to use the same tube, but i am just wondering if the sharp edge (where the tube is slotted) wont hurt the where the cables come out of the harness.... ??? Of course i have tapped the cables before i put it in the tubes... but i guess of all the vibratons of the engine the sharp edge will cut it through... I hope u understand what i mean !! :-) Thanks for ur help CU Achim |
12-15-2014, 08:15 AM | #2 |
Re: ls1 harness how to protect the wires
Here it is frequently called split loom. Most of the time you will see just a few extra layers of tape where your wirirng needs to exit the loom. If you want a really clean look you can get something like this. Just make sure it is engine temp safe.
http://www.cableorganizer.com/wire-l...-loom-tees.htm |
12-15-2014, 03:24 PM | #3 |
meowMEOWmeowMEOW
There are different types of this stuff that all do the same job. You can also look at "braided loom" which looks like a Chinese Finger Trap, and is a bit softer and more flexible than the other stuff.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
12-16-2014, 12:29 PM | #4 |
Boosted Member
I use Techflex braided loom on all my harnesses. You can get it in the solid "finger trap" style like Brew mentioned, and you can also get a split version of it.
http://www.techflex.com/land_genpurp.asp
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
