Old 12-15-2014, 02:25 AM   #1
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Duramax stand alone
Looking at doing a swap into a 1961 chevy crew cab. I got a 2003 wrecked duramax/allison with about 200k. I've seen all the companies selling the stand alone harness but was wondering if anyone here has done one. I only plan on using motor. Not anything electrical from firewall back. Also read that you can convert a 4x4 tranny to 2wd. Any help would be great. Chizzler.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 12-15-2014, 03:26 AM   #2
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Duramax stand alone
72Duisburg purchased one for his blurb a few years ago from PPE, and was less than impressed. I used one from a marine boat manufacturer years ago in a tractor, but I can't remember their name now. Another member on this board just did a 71 or 72 K20 with a dmax, and he used all the factory wiring on his truck. For the cost of a stand a lone harness, I'd register on Mitchell's online site and do it myself. I'll find the link for you tomorrow. It's like $16.99/month. I've used it on the last 4 trucks I've done. I get a month subscription, and print out everything I need within the month. It has part locator sections and.all kinds of info that can be helpful. Your 2wd trans can be converted by replacing the out put shaft and tail housing. (I think) I've got a 2wd a1000 from a bread truck with the park brake on the back of it. It has 3500 miles on an Allison reman. I'd sell it if you're interested. Your bell should bolt to it and you should be able to use this one's torque converter too.
Ryan
1969 Chevy milk truck
Old 12-15-2014, 02:05 PM   #3
Dieselwrencher
Here is that link to the mitchell site I use.
http://www.eautorepair.net/app/Years...FaHm7AodRCkAvQ
Ryan
Old 12-15-2014, 09:12 PM   #4
CHIZZLER
CHIZZLER's Avatar
Thanks for the info.
61-crew cab D-max
Old 12-16-2014, 05:46 PM   #5
Dieselwrencher
Have you seen this one yet?
http://www.btdieselworks.com/product...wiring-harness
Ryan
Old 12-16-2014, 05:54 PM   #6
CHIZZLER
CHIZZLER's Avatar
yes i have seen that one. to me it seems like the best one. there is also another one posted on flea bay that has a youtube video with it. seems very easy to hook up. please pm me any info on that 2wd allison. thanks chizzler
61-crew cab D-max
Old 12-16-2014, 06:08 PM   #7
Dieselwrencher
It would be a bit to spend, but you'll have quite a bit of time in re-vamping your original harness. I like doing that kind of work, but finding the time to do it is what gets me anymore.
Ryan
Old 12-31-2014, 02:07 PM   #8
joel.e
joel.e's Avatar
I tore apart an original harness for my lb7/allison install. Mine isn't as clean as the ones you purchase but I left alot of the wires tied up in case I decided to use some other functions later plus I didn't know how my ecm's would be mounted at the time. I can get you some pin numbers for constant hot (most orange wires) and switched hot on others (most pink wires) to get it running. As others above mentioned, I just printed off all the diagrams from Alldata and started going through circuit by circuit to see if I needed it or not.
1967 C10 SWB Fleetside Duramax/Allison
1966 Chevelle Malibu, EFI BBC, pro touring starter kit
joel.e is offline   Reply With Quote
Old 02-23-2015, 09:22 AM   #9
72duraburb
check out www.standaloneharness.com I am having him do 2 harnesses for me right now. 1 is from 08 chevy Dmax van and other is lbz. seems like he really knows his way around these. I will have mine back by the end of the week. cost is 545.00 with return shipping and takes him 5-7days to complete
72duraburb is offline   Reply With Quote
Old 03-27-2015, 03:09 PM   #10
Luther Grimace
Luther Grimace's Avatar
This seems like a really reasonable cost to do this. Are you satisfied with how it turned out?
I have an 06 LLY van that I want to make standalone but I want to retain the 4L85E. Was this guy able to keep the transmission?
1955.2 Chevy 3100, 6bt, Getrag G360 5-speed, NP205, Dana 60/70 - http://67-72chevytrucks.com/vboard/s...d.php?t=536540
1992 Chevy K1500 Silverado ECSB
1965 "Crewcab" Chevelle 300 Deluxe - soon to be LBZ Duramax/4L85E powered
Luther Grimace is offline   Reply With Quote
Old 03-27-2015, 09:16 PM   #11
72duraburb
He did a very good job! Ken Woken is his name and he did everything he said he would and finished them in the time he said also. Highly recommend! !!! It no ppe hack job
Old 04-03-2015, 11:22 PM   #12
CHIZZLER
CHIZZLER's Avatar
this is the same guy im going to work with.
61-crew cab D-max
Old 06-15-2015, 06:19 PM   #13
Russell
Professional Grade
Russell's Avatar
These harnesses are no more difficult to re-work than an LS engine is. The wiring is very similar. I'd be happy to help folks work their way through them if they want. Just shoot me a PM!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
