Old 12-16-2014, 07:16 PM   #1
'63MurderTruck
'63MurderTruck's Avatar
Transmission Swap - Question
Okay,
'63 Stepside C-140
We're replacing the 3 speed manual tranny with a Turbo 350.
The engine is a I6 250.
My question is: Will the current "cross member" work, or will I need a different one?
Thanks in advance
'63MurderTruck is offline   Reply With Quote
Old 12-16-2014, 07:19 PM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Transmission Swap - Question
You need to get an automatic crossmember.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 12-16-2014, 07:21 PM   #3
'63MurderTruck
You have any links or suggestions where to get one? Thanks
Old 12-17-2014, 12:36 AM   #4
DPowers
One foot in front of the other
DPowers's Avatar
Look for one from a '67-72 or make your own.
DPowers is offline   Reply With Quote
Old 12-17-2014, 01:45 AM   #5
Captainfab
60-66 Nut
You will need to remove the bellhousing crossmember and install an auto trans crossmember from a '63-'87 2wd truck, Blazer or Suburban.
Old 12-19-2014, 10:45 PM   #6
mikejnang
i did this same swap a while back. used a piece of angle iron maybe 2x2 or 1 1/2 x 1 1/2 inch. the angle iron sat in the frame rail. get a trans mount block to attach trans to angle iron. in other words, the bottom of the trans will be level with the bottom of the frame rails. Not the strongest of cross members but with the stock I6, it worked fine. drove truck daily for years like this. cost maybe 20 dollars for parts. Sorry i never took pics of it.
mikejnang is offline   Reply With Quote
Old 12-20-2014, 08:27 AM   #7
bj383ss
bj383ss's Avatar
Here is a pic of the crossmember you need to remove. It is the second one from the front.
DSCN7924 by bjohnson388, on Flickr
It has rivets on top and bottom you have to grind off.
DSCN7929 by bjohnson388, on Flickr
And here is a pic of the auto trans crossmember I got from CPP for $100 with poly mount.
DSCN8274 by bjohnson388, on Flickr
The PO of my truck had used the emergency brake crossmember to mount my trans no good. He also just torched out part of the bellhousing crossmember to make the trans fit. And it was mounted so that the pan could not be removed. All half A$$ed.
Here is the engine and trans in.
DSCN8280 by bjohnson388, on Flickr
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 12-20-2014, 01:51 PM   #8
padresag
here is a picture of an OEM crossmember
has the emerg brake hook-ups with it
ron
padresag is offline   Reply With Quote
Old 12-20-2014, 02:00 PM   #9
63longfleet
you might try JC's truck salvage down the road from you in Bridge Creek, he has never failed to have what i needed.
63longfleet is offline   Reply With Quote
Old 12-21-2014, 01:02 AM   #10
Captainfab
60-66 Nut
When installing a trans crossmember, you need to be sure that the angle of the output shaft is parallel to the pinion. Otherwise you will have driveshaft vibrations. This is one of the reasons I prefer to use a factory trans crossmember.
Old 12-21-2014, 12:05 PM   #11
Chevy Fleetside
I found mine in a pick and pull out of a 67. I have one out of a 66 that will go in my daily driver. I am not looking forward on taking out the bell housing cross member. PITA with the engine in and the cab on but doable.
Old 10-17-2015, 11:28 PM   #12
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
So funny.
I'm in the middle of doing the swap from my sm420 to a th350, and was searching the forums for related topics.
I ran across one thread where a very nice clean install pic showed the manual crossmember still in there. My first thought was "Crap, was I supposed to leave that in there for frame rigidity?!!!!" eek!
But started searching again because I was sure I saw others with it gone.
Whew, found this thread... I'm good now.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
