12-16-2014, 10:18 PM | #1 |
Porterbuilt, Boyd Welding, Doug Thorley, CPP and others.
All parts OBO. Will state is shipping is included or extra in item description.
1. !SOLD! Boyd Welding fuel tank. Carb/Bed Fill. $300.00+Shipping 2. !SOLD! Holley Ultra Double Pumper Carb Black. 750CFM. All hardware and gaskets included. $485.00+FREE 3. !SOLD! PB Trac-Bar with frame bracket. Black powder coated. All hardware is included. $75.00+Shipping 4. !SOLD!PB Trailing Arms kit. Black powder coated. All hardware is included. $400.00+Shipping 5. !SOLD! PB Control Arms Kit. Black powder coated. Ball joints already pressed in lower arms. Stock Crossmember, standard length, coil spring adapters. All hardware included. $950.00+Shipping 6. !SOLD! CPP Big brake kit. Front and rear disc. 13" front, 12" rear. 2" drop spindles. 5x5 kit with plain calipers. 1350.00+Shipping 7. CPP Chrome 9" dual diaphragm with master. Built in prop valve, 1" bore. Part#'s CP31500-C, 9DSRB-C. $285.00+FREE 8. !SOLD! CPP front sway bar kit. 1-1/4" black. Part#CP7423-Black $95.00+FREE 9. !SOLD! CPP front sway bar bracket for lowered trucks. $10.00+shipping 10. !SOLD! CPP stainless steel brake line kit. 67-70. Part#6770FLK-SS $100.00+FREE 11. !SOLD! CPP shock studs pair. Part#CPSMS. $8.00+Shipping 12. 13. !SOLD! CPP shock relocation kit. Black powder coat. Part#6372SRK. $25.00+Shipping 14. !SOLD! CPP idler arm. 67-82. Part#FA619 $10.00+Shipping 15. CPP 65-70 tie rod end. Left. Part#ES350L. 2 total. $8.00+FREE 16 CPP 73-87 conversion outter tie rod end. Part#ES409R. 2 total. $8.00+FREE 17. !SOLD! Doug Thorley Headers for LS series swap. All hardware and gaskets. Never torqued to motor just mounted to check fit. $595.00+FREE 18. !SOLD! Early Classic rear crossmember black powder coated. $30.00+Shipping Last edited by 1968Mann; 12-26-2014 at 01:54 AM. Reason: Shipping changes. |
12-16-2014, 10:23 PM | #2 |
Re: Porterbuilt, Boyd Welding, Doug Thorley, CPP and others.
pass
12-16-2014, 10:26 PM | #3 |
Pics:
12-16-2014, 10:38 PM | #4 |
Pics
12-16-2014, 10:44 PM | #5 |
pics
12-16-2014, 10:32 PM | #6 |
Picture of 8. Can you tell me the measurement from center eyelet to center eyelet... Where the links would go.
Thanks, Travis |
12-16-2014, 10:59 PM | #7 |
12-16-2014, 11:00 PM | #8 |
Interested in front/rear brakes. What all is included? Do you have a part number or which ones are they on cpp page? Thanks, Dustin
12-16-2014, 11:07 PM | #9 | |
On first page under big brake kits on CPP 67-72 truck page. These if i remember right have both from and back slotted and drilled rotors. I know there is a ton of different things included with it. CPP page has everything though under that part number. It does not include the master cylinder or prop valve since i upgraded to the chrome one. |
12-17-2014, 01:11 PM | #10 |
12-16-2014, 10:38 PM | #11 |
I'll take the CPP idler arm and the CPP sway bar bracket. Thanks PM me payment info.
Scott |
12-16-2014, 10:39 PM | #12 |
I'll take the Porterbuilt trac bar too.
Scott |
12-16-2014, 10:44 PM | #13 |
Can I just give you $150.00 for everything shipped.
That way you don't have to hassle with trying to figure out actual shipping.
Scott |
12-16-2014, 11:04 PM | #14 | ||
Paypal is dreamscapeslls@gmail.com |
12-16-2014, 11:13 PM | #15 | |
Scott |
12-16-2014, 11:15 PM | #16 | |
Check or cash Zack Mann 8105 N. Coffelt Cemetery Rd. Bentonvillle, Ar 72712 I didnt think it was a bad deal if you can stand the black coating already! i know they will defiently be ok with getting that part out. I always enjoyed ordering from PB! Last edited by 1968Mann; 12-16-2014 at 11:17 PM. Reason: add |
12-16-2014, 11:20 PM | #17 | |
Scott |
12-16-2014, 10:54 PM | #18 |
Pics
12-16-2014, 11:02 PM | #19 |
4. PB Trailing Arms kit. Black powder coated. All hardware is included. $400.00+Shipping
looks like these arms do NOT have a drop built into them?! Correct? |
12-16-2014, 11:11 PM | #20 |
I want to say they do not have a drop built into them but they might be the 2" drop because I have 3"drop springs for the rear and I was doing a 4/5" drop on the truck I think.
12-16-2014, 11:30 PM | #21 |
I'll take the shock studs.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
12-16-2014, 11:54 PM | #22 |
12-17-2014, 12:02 AM | #23 | |
12-17-2014, 12:03 AM | #24 |
12-17-2014, 12:08 AM | #25 |
Payment sent.
