Dash brace
Is there a dash brace that goes from the firewall to the steering column mount bolts? if so does anyone have a picture of the brace and one of it installed? also is it really necessary?
I have one that looks like it would be for that but it is slightly to long , or it is not the correct one. Thanks Mike
1950 3100 5 window |
Hollister Road Co.
Re: Dash brace
it is hard to get in and out and it is needed
here are some picture that show most of it |
Re: Dash brace
Thanks Dave.
Re: Dash brace
I think that brace is pretty much required, it not only holds the dash in place it also braces the steering column if it is attached to the dash - I suggest using it. 2 bolts under the dash, 2 bolts on the firewall are stock, or a good welder.
![]() Join Date: Mar 2011
Re: Dash brace
I kept my brace and attached it to a 1-1/2" angle I installed to tie the A pillar together when I removed the stock dash and installed another type. I also welded the two bolts going thru the firewall to the firewall, so it was smooth on the outside cowl firewall area. Here's couple pics showing the brace...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
Re: Dash brace
Can you buy replacement dash braces? Not to high jack post but I need a replacement one and did not see in any of my parts books.
My Build: 1948 Chevy Thriftmaster. Mustang 2 front end, LS1, 700R trans, Explorer Rear end. ![]() http://http://67-72chevytrucks.com/vboard/showthread.php?t=606670 |
Re: Dash brace
I made my own, very easy.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
Re: Dash brace
Classic Ind. replacement dash ad states it comes with the firewall brace - you might call and ask them if just the brace could be available - or any of the replacement body part dealers - maybe....
![]() Join Date: Aug 2012
Re: Dash brace
Agreed that this is a straighforward part to fab up yourself - here's what was done on my truck:
Build Thread: "Marvin" (1953 3100) |
Re: Dash brace
I found it thanks to Dave's picture.
