Old 12-20-2014, 08:37 PM   #1
wick22
rearend id help
rearend is in my 57
its a 12 bolt and has a eyelet on top of rearend for a panhard bar and is 6 lug
wondering what year rearend i may have
wanting to change to 5 lug but wanna order correct parts
any advise is apreciated
looking at axles at summitracing YA G3893606
wick22 is offline   Reply With Quote
Old 12-20-2014, 09:12 PM   #2
1project2many
Re: rearend id help
Pictures might help. If it's a stock axle, 12 bolt cover and six lug axles is probably a truck 12 bolt. It's not as strong as a car 12 bolt but it's usable for many applications. Does this axle look like yours?
The Yukon axles might work. Double check length before ordering.
1project2many is offline   Reply With Quote
Old 12-20-2014, 09:23 PM   #3
Donaldo
Re: rearend id help
I just narrowed my GM 12 bolt rear end, dealt with Moser Axles - they were quick, and even better - they fit the first time !
You can get a work sheet off their website, call them with the measurements you want.
I found them really easy to deal with.
Thanks, Don
http://www.donsbirds.com/pick-up
Donaldo is offline   Reply With Quote
Old 12-20-2014, 10:21 PM   #4
Highsider
Highsider's Avatar
Re: rearend id help
12-bolt, but no eyelet. What do you'all think I have?
There are numbers on the top passenger side axle, but I can't read them very well.
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 12-21-2014, 12:34 PM   #5
1project2many
Re: rearend id help
12 bolt truck. Rear cover is unique to that rear. Need numbers to try and narrow it down.
Old 12-21-2014, 12:44 PM   #6
wick22
Re: rearend id help
there are numbers on it ill get them
id def like to id specific year and specs on it
i do know its a 3.73 open diff
Old 12-21-2014, 01:10 PM   #7
57chevyman
57chevyman's Avatar
Re: rearend id help
looks like the same 12 bolt rear i have in my truck from a 1972 chevy truck
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline   Reply With Quote
Old 12-21-2014, 01:30 PM   #8
Highsider
Highsider's Avatar
Re: rearend id help
Tell me what that "panhead" bar does?
I was thinking mine was stock for the original 6-cylinder it came with and had a 3.73 ratio.
I have 5-bolt, but I wondered if that has been updated. I can't recall how many lugs my
1955.2 I owned when I was 16.
'57 Panel 3105
Met this deer...
Jim's Bread Truck
Old 12-21-2014, 04:10 PM   #9
1project2many
Re: rearend id help
The 67-72 Chevy truck had rear coils. The panhard bar keeps the truck located properly. That was done so the Nascar boys could run a three link coil sprung rear end. They still use it today. GMC got coils in '67 too but they had a bad tendency to wheel hop in mud and loose dirt so GMC switched back to leaves in '68 or '69.
Old 12-21-2014, 05:57 PM   #10
1project2many
Re: rearend id help
Want to add to the above:
First year for coils was '60, not '67.
Article and pictures here:
http://www.earlyclassic.com/Tech.asp...;s+Makeover+II
