12-21-2014, 04:15 PM | #1 |
56 step side on 07 trailblazer chassis
hi everybody im new here and here is my actual project,im a truck guy and my last truck before this was a 1946 p/u on 55 belair chassis 3 years ago in my country Uruguay before i come to canada. after that i work here in my first project 81 trans am with 455,and now im happy to work in a truck again.so i found this truck and i decide to build a daily driver that means change everything except the body,after some search for a donor power train i found a 07 trailblazer and then i start 1 month ago with the puzzle
12-21-2014, 04:29 PM | #2 |
Re: 56 step side on 07 trailblazer chassis
First, Welcome! Looks like you have a good start to your project. Is the Envoy a V8? If so, you really are off to a good start. Check out my 1955 build on a Trailblazer frame (first link below). I started with an Inline 6 frame, so I have had to piece the V8 parts together. My truck is approximately 8 inches off the ground with full suspension travel. I used the full floorpan from the trailblazer (I plan to use the trailblazer carpet, seats, gas tank, exhaust, and anything else I can think of). You will love these engines, they make a lot of power and get relatively good gas mileage. Please post up your work, It helps us all.
Ricky
Rick's 55 TF/Fleetside/LSx build 1958 Corvette LS1/T56 Build 1966 GTO LQ9/T56 Restomod |
12-21-2014, 04:42 PM | #3 | |
12-21-2014, 04:45 PM | #4 |
the challenge in all this was do all this by my self without the proper shop and tools, all the tools that i have is a little red tool box (you can see it in some pics after) and a 1t rusty engine hoist
so i start with all this without know how i go to do,so the first challenge for me was remove the complete trailblazer from the chassis,after some days thinking and thinking nothing come to my head so what i do is just start taking out bolts,after that take out the weight(interior,fenders,doors) and all the connections. |
12-21-2014, 04:53 PM | #5 |
i take to many measures wheelbase , body mounts and every point starting from the center of the front wheels because that is the reference for everything
because the most important is keep the front wheels centered in the wheel fender space, every can be changed except that |
12-21-2014, 05:02 PM | #6 |
at that point i still without know how i go to take out the body but im keep going,after i lift the front of the body with the hoist an a idea come to my head build a support with wood and that is what i do, when i finish with that i just take out the hoist and lift the back,done! i just push the chassis out and clean the driveway of all that crap
12-21-2014, 05:23 PM | #7 |
the trailblazer is perfect for work look complicated but is not, im only use 7 tools for do all this from the first time 7mm,8mm,10mm,13mm and 18mm sockets and keys, flat and phillips screwdriver
12-21-2014, 05:54 PM | #8 |
before i send the tb body for scrap i take out all the necessary and some more just in case,the most important piece is part of the floor with the tranny and transfer shape that make me save a lot of work and time building a new floor in the 56 cab and keep the original mount for the tb seats ,handbrake and shifter. of course i save all the wires,power windows and complete dash.
after i have the tranny shape i put the 56 cab on the tb chassis to see what happens (i put the fenders hood and front to but forgot take pics before take all out) everything ok but my idea is drop the body to around 5 or 6 inch from the floor but the front wheels touch the fenders when turn and that rims are like 0 offset so no room to put others rims by the way no easy to find rims 6x5 and no way to put adapters of course, for now my solution is put small tires than thats but that after i finish with the body |
12-21-2014, 05:28 PM | #9 |
Welcome.
Looks like a real neat project. Kim |
12-21-2014, 06:06 PM | #10 |
12-21-2014, 06:15 PM | #11 |
here some pics of the tb dash on the 56 dash just watching possibilitys but i dont like to much the idea .the only positive is that i can use all the tb component in the dash ,but i find the way to keep the stock 56 dash and all the electronic measurements , i know are the dakota 56 electronic gauges in ebay but i have a very easy way and cheap and for my better look .so the dash and gauges go to be the original 56 for sure.
this is all for now ppl |
12-21-2014, 07:02 PM | #12 |
12-21-2014, 06:48 PM | #13 |
Nice work. Looks like you have a good start on it.
12-21-2014, 07:11 PM | #14 |
12-21-2014, 09:00 PM | #15 |
You're doing a great job with the limited equipment you have.
Kim |
12-21-2014, 11:17 PM | #16 |
neat.
12-29-2014, 11:22 AM | #17 |
wow, you got a lot done since I checked in last time. too bad you didn't snap a few pics with the front end on showing the tire problem. I am doing the same thing with a all wheel drive xuv but so far am still working on the cab bodywork to get it so I can put it onto a frame. no floor right now so that is a little difficult, ha ha. keep the pics coming, you are doing great. are you dealing with snow and cold like we are in Calgary right now?
dennis |
12-29-2014, 03:37 PM | #18 |
A320 Pilot/USAF Retired
Nice project, looking forward to watching it come along!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
01-22-2015, 12:51 AM | #19 |
So here we back with some news after all the vacation and stuff, i take a little brake off everything including working phone internet wifi etc. and dreaming with come back to my country but im still here keep going... ok so i done with some welding work on the floor cab, cleanup and paint underneath ,welding the cab mounts and giving some cleanup to the chassis and paint
01-22-2015, 01:02 AM | #20 |
i cut around 1" of the rubber in the rear mounts, i take out the rear springs and put the chassis in the level where i like to leave the truck with all the weigh of the bed etc. and put the cab in level with the ground .after i have to play with the springs for keep that high. here is a pic of the wheel space that i talk about before ,no to much room but i think if i change the front tires go to be ok ,but the bad thing is the truck cant be lower than that ,believe me i try everything and no i dont wanna play with the fenders but we see what happens with some low profile tires
01-22-2015, 01:08 AM | #21 |
here i cut the front of the chassis the less that i can ,not leave me to much room for radiator and a electric fan but i like challenges,definitely no room for A/C radiator so no a/c in this truck
01-22-2015, 09:38 AM | #22 |
You're making some good progress.
Looks good. Kim |
01-22-2015, 06:21 PM | #23 |
01-22-2015, 07:07 PM | #24 |
hey rusty, you are making some great progress. looks like your snow is gone. not so much here in calgary but we are working on it this week. thanks for posting all those pics. it makes my mind start thginking about how i will do my truck. it is basically the same thing as what you are doing out there. my donor is an 04 envoy XUV, so it has the 6 cyl and awd just a little bit longer that average and the body is a bit different inside because thay have a midgate and window that comes up or dow, that will all be gone anyway so no matter. I have some pretty big concerns over the wheel fitment on the front fenders though. it doesn't look like there is a lot of room to do a turn if the truck is going over a bump at the same time. will you have to run a different offset wheel? maybe camber the wheels a bit up front? there is one of these online that lingenfelter did from all new parts. look up lingenfelters erod truck. it looks like the front tires are cambered extra and the write up says they used wheels from a chevy 1/2 ton. I assume they had to use the wheel bearing hubs from the 1/2 ton then because the bolt pattern is different from the envoy to the regular 6 stud pattern for chevy trucks. got any ideas?
dennis gonna start working on my truck in feb, hopefully. |
01-22-2015, 08:28 PM | #25 | |
