Old 12-21-2014, 06:53 PM   #1
65burb65
Captian fab does p/s gear box go inside or out
Does the gearbox bracket I bought from you go on the inside of the frame around or on the outside of the frame rail
65burb65 is offline   Reply With Quote
Old 12-21-2014, 06:54 PM   #2
65burb65
Re: Captian fab does p/s gear box go inside or out
Rail not around
Old 12-21-2014, 08:11 PM   #3
padresag
goes on the outside between the str box and the frame so that you can mate the box to the frame
http://www.67-72chevytrucks.com/vboa...d.php?t=332923
ron
padresag is offline   Reply With Quote
Old 12-21-2014, 08:22 PM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Outside like this,
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 12-21-2014, 11:21 PM   #5
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
also as a hint, use it for a guide to drill out that lower left hole, since the factory hole is kinda close it is a real pita to get the hole right, on my second bracket I used it as a guide and it came out a perfect circle!
you can see the og hole in the picture on the previous post.
Old 12-22-2014, 01:16 AM   #6
donthekawguy
donthekawguy's Avatar
I used the template and cut an X into the spots marked as original holes, then center punched where the new holes go and drilled them out. The bottom left was still a little close to the bottom part of the frame so I used a allen head bolt.
66 shorty
donthekawguy is offline   Reply With Quote
