Old 12-21-2014, 09:18 PM   #1
az1970k5
az1970k5's Avatar
pedal bolts?
So I snapped the little screw on which the gas pedal attaches, anybody have any ideas? I couldnt find any reproductions unless im not looking in the right place. I thought about welding it. What ave others done?
az1970k5 is offline   Reply With Quote
Old 12-21-2014, 09:57 PM   #2
PETEM1957
Junior Member
Re: pedal bolts?
Had two break off. Got an aftermarket pair from a vendor. Drilled oversized holes through the broken pieces. installed new studs with nuts on the bottom side of the floor panel. The replacements were long enough and it worked like a champ. No welding required!
PETEM1957 is offline   Reply With Quote
Old 12-21-2014, 10:01 PM   #3
az1970k5
az1970k5's Avatar
Re: pedal bolts?
Do you know whay they are actually called?
Old 12-21-2014, 10:13 PM   #4
PETEM1957
Junior Member
Re: pedal bolts?
LMC catalog page 51 item # 4- Accelerator pedal stud
Old 12-21-2014, 10:10 PM   #5
GMC-YA68
GMC-YA68's Avatar
Re: pedal bolts?
Is it a threaded ball stud? Like you would use on a gas shock for a newer style hood or hatch?
http://m.napaonline.com/tablet//part...608_0361162040
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
