12-24-2014, 05:07 PM | #1 |
Clutch Pedal Bushing Help
I need to replace the bushing the bushing that inserts into/between the clutch linkage and pedal assembly. While trying to diagnosis a squeak in my clutch, I noticed this bushing is half gone.
I have checked three different local parts shop and can't find one. I was also looking online and can't find the right size. The bushing measures 1/2 outside diameter, about 1/2 long and is made of plastic. Any suggestions on where I can get one? Thanks for your help! image by Luftwaffepdx, on Flickr image by Luftwaffepdx, on Flickr |
12-24-2014, 05:15 PM | #2 |
Re: Clutch Pedal Bushing Help
i know its been an issure trying to find these. i pulled the clutch out of my truck and saved these bushings as they were stuill in good shape. i have them up for sale in the parts section ill ttt the ad now for you
1967custom |
12-25-2014, 07:11 PM | #3 |
2WD Jimmy
I had a BB new old stock z-bar setup. It had no bushing there. Is it a possibility the hole was worn and the previous owner installed a bushing the he had or was able to find that worked. If it was me, I would weld the hole shut and re drill it so it's not O'd out. You could look at the LMC Truck parts catalog online, they have a schematic that shows all the parts. I don't think you will find a bushing there, but I could be wrong.
12-25-2014, 08:38 PM | #4 | |
12-25-2014, 07:55 PM | #5 |
My linkage bar is sold but i have that arm if yours is all wallered out
1967custom |
12-25-2014, 08:40 PM | #6 |
I guess I hadn't diagnosed the situation soon enough to act on your FS parts. My linkage bar does have wear on one side. I'm not sure if the bushing will solve the problem or long term I will need to replace the linkage bar.
12-26-2014, 02:00 AM | #7 |
If its not too wallowed out a bronze bushing or steel sleeve might work.
12-26-2014, 02:01 AM | #8 |
I am not sure of the size but maybe a door hinge bushing would work.
12-26-2014, 10:47 AM | #9 |
All about them K’s
The extra clutch parts I got with my truck have no bushings there, only where pedal shaft moves in the brake pedal sleeve. I'd do like stated above and grind the burr off and weld it up solid then re drill the hole. The clutch pedal will come out pretty easy without taking the brake pedal assembly/ bracket out of the dash.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
