12-24-2014, 06:36 PM | #1 |
Front brake wheel cylinder removal issues
I cannont get the wheel cylinder bolt loose on the passenger side. This is the single bolt version that holds on the wheel cylinder. Is this by any chance a left hand thread? I have beat it, out the pb blaster, cheater bar, i even drilled a small hole in the top of the cylinder flange at the top of the cylinder hoping the pb blaster could penetrate the threads. I assume this is a normal right hand thread but would listen to any advise. Thanks
12-24-2014, 06:38 PM | #2 |
Re: Front brake wheel cylinder removal issues
This is a 1966 by the way
12-24-2014, 08:21 PM | #3 |
is this the big bolt that goes through the wheel cylinder? it should have a nub on the end of it that holds the springs that attach to the brake shoes. if so, its just a normal leftsy loosey thread. you have access to a pneumatic impact gun? thats usually the only way that i can get them off.
12-26-2014, 09:32 AM | #4 |
heating it up first help,s then use breaker bar and pipe look,s like thread lock insde
12-26-2014, 12:19 PM | #5 |
Good luck. Do your best not to strip the bolt head. It took me about two hours to get this thing off. Keep hitting it with a penetrating fluid and heat the head if you have a torch. let it cool get a large breaker bar for the most leverage and good luck!
10-13-2016, 07:00 AM | #6 |
What about putting them back on? I haven't found the washer and torque?
I have a 70 btw
1966 Chevelle SS 396 1970 C-10 project (for sale) 1984 Chevy C30 Ramp truck My YouTube |
Tags |
wheel cylinder |
