![]() Join Date: Nov 2009
Chelsea PTO, for SM465
I took this off of a truck I once had. It was mounted to the left side of the sm465 on a 3/4T 4wd truck. It seemed to work fine but it wasn't driving anything. So I removed it thinking that someday I might have a use for it. That day isn't going to come. It could use some cleaning. $175 shipped lower 48
![]() Join Date: May 2013
Re: Chelsea PTO, for SM465
Hi Mike.
What kind of shape is the shaft in ? Any excessive wear ? How are the gears ? Do you have the cable and floor mount ? Thank you much
Tom 71 K2500 71 K5 Jimmy |
The shaft is in good condition without any excessive wear that I noticed. The gears looked good as well. And, no, I don't have the cable and floor mount. It does engage and disengage easily.
Thanks Mike.Sounds good.
So,all I need to install would be cable and floor mount ? Do you have the mounting bolts ? Would you consider $150 shipped ? Thanks.
I don't have the mounting bolts. They were used to install the cover plate back on the transmission. You would need a cable, like a transmission shift cable, or something similar, and a mount with a knob or something for engaging and disengaging the pto.
