Old 12-30-2014, 05:02 PM   #1
jbgroby
jbgroby's Avatar
Vent Window Rivets - Settign tool
Hey gang,
I want to try and finish my doors and of cource a large part of that is new rubber in the vent window assemblies. I can chicken out and buy the new assembly pre-made and just drop them in ($250.00 a pop), but would like to at least TRY to do it on my own. I seen a few threads that speak on this but I think I need a tool that will set the rivets, using a hand punch and hammer is going to be a PITA, do they make a tool I can purchase that will help?
I found this on ebay , but was unsure if it is correct or not for the use. I'll only use the tool for these vents - one time use I suppose.
http://www.ebay.com/itm/New-Chain-Cu...ht_3824wt_1255
Anybody have some ideas I can try?
Jake
jbgroby is offline   Reply With Quote
Old 12-30-2014, 07:14 PM   #2
63burban
Chevy addict
Re: Vent Window Rivets - Settign tool
This Ebay kit is strictly for roller chains
63burban is offline   Reply With Quote
Old 12-30-2014, 07:25 PM   #3
SIR
SIR
SIR's Avatar
grind down the tip of your "pop rivet" tool and use that....
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 12-30-2014, 09:02 PM   #4
MisterC
MisterC's Avatar
Hey Jake,
I'm not sure if you've browsed this thread yet, but I think there were several replies that discussed tool options
http://67-72chevytrucks.com/vboard/s...d.php?t=351471
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 12-30-2014, 11:13 PM   #5
slorio
slorio's Avatar
Jake:
I used pop rivets on mine with no problems. The pop rivet gun I used came from Harbor Freight and has interchangeable dies for different size rivets. The dies were narrow enough to get into the channel with the pop rivets. The only choice that I made was to leave the "pivot rivet" alone and instead remove the two rivets that hold that bracket to the frame. The "pivot rivet" is the one that I think gives most folks a problem. See the write up that Mister C references for this issue.
Regards,
Steve
PS Your 1960 vents are likely to be different from the pictures that these folks are using for a 1964-1966.
slorio is offline   Reply With Quote
Old 12-30-2014, 11:32 PM   #6
jbgroby
jbgroby's Avatar
Thanks Guys for the replies. I need to get an extra set of hands.
Old 12-31-2014, 12:26 AM   #7
Joe Pass
Joe Pass's Avatar
I just finished mine and I suggest pop rivets over the setting tool/steel rivets. As careful as I was, the setting tool bends/distorts the rigid vertical seal when trying to mushroom over the end of the rivet. Its like the process is to much for the seal to with stand and survive the install. Practice with some steel rivets on some scrap be fore you take a run at it. I used 3/32" all aluminum rivets with the aluminum pull shank. It will nestle down in there and the tail will be pretty flush. wont rust and you can dress them down a bit if needed.
Joe Pass is offline   Reply With Quote
Old 12-31-2014, 06:45 AM   #8
jbgroby
jbgroby's Avatar
Joe, the Sears pop rivet gun I have leaves a long tail, do you grind that off?
Old 12-31-2014, 09:32 AM   #9
Joe Pass
Joe Pass's Avatar
You can trim the tails off so they are flush. Usually when the tails brakes off long you are using a grip length to long. I use an all aluminum rivet/tail type that is kind of short, just enough length to work. These wing window seals don't need to much clamping force from the rivet or it will distort. An old Fart glass guy (my uncle Joe) showed me this trick, he also glues the seal in place (carefully) then rivets it after so it will stay in place .This assists the rivets in holding seal and makes it easier to assemble by yourself.
Good luck...Happy New Year
Joe
