Old 08-20-2003, 10:36 PM   #1
gmc71
gmc71's Avatar
4x4 conversion???
Hey 4x4s I'd like to move over to this board full time but first I need the truck, do you think you can help?
I have a 71 GMC LWB 2wd. How do I go about making her into a 4x4. I have inspected the frames on some 4x4s and believe they are essentially the same.
1. First I would have to scrap the front end and make room for the leaf springs (bolt on) and front axle(dana44).
2. Then and put in a crossmember for the transfer case.
3. Hook up the new drive shafts, and I'm off to the bogs....right, or no its not that easy....
Please explain, or post some helpful tips..... or email me at: bdheeter@adelphia.net
gmc71 is offline   Reply With Quote
Old 08-21-2003, 01:13 AM   #2
Scrub
Collector of rusty Items
Scrub's Avatar
The frames are completely different. A 4x4 frame is like 2 inches narrower than a 2x4. My advice, find a 4x4 frame. I picked one up for 50 bucks, but that is really cheap. I bet you can find one for 200. Believe me, you will not regret it.
You also need a tranny/tcase plus all the linkage. Then you need a different steering box, unless you do a crossover, because the 4x4 is different than 2x4 steering box.
I started to do a conversion, but it was cheaper to just buy a 4x4.
good luck
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 08-27-2003, 10:47 PM   #3
Rod
Find a 4x4 frame ... 1/2 ton 3/4 ton. truck or suburban 4x4 .. all easily will become a truck 4x4 frame. Much easier swap than taking a 2wd frame and making it 4x4. Just a rolling frame goes for up to $800 here without transfer case and tranny.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 08-28-2003, 12:20 PM   #4
JimKshortstep4x4
Smile
It is too bad that you are so far away, the yard where I shop a lot has a real decent frame with front and rear differentials that they would sell for $250. It is a 71 or 72 1/2 ton so it has front disc brakes.
Jim
