![]() Join Date: Nov 2001
Any one have a 1967 truck with 327 engine?
I am interested in information from those of you that have a 1967 1/2 ton truck with a original to that truck 327 engine.
I am also additionally very interested in one that was built sometime in the Dec 1966 timeframe (early 1967 truck built date potentially), just to get some info. I am trying to determine a casting date in relation to a 12/20/66 engine assembly date, block casting number, cyl head casting numbers... among other things. After some education from another board member (thank you SS Tim) I am again/still searching for a 327 engine out of a 10-20 series truck with a K-xx-6 thru L-19-6 casting date. One that the front pass cyl head pad is stamped V1220YH or shortly before such date, such as 12-01 to 12-19 would be awesome. What this code means: V = built in Flint, Mich 1220 = Dec 20th 1966 YH = connected to a TH400 engine. I am not looking for just any old 327 block/engine, as I have one or two already and have access to a few others. I am kind of believing that finding a V1220YH (or slightly earlier) stamped block may not be as impossible as I originally thought. So... Here we go !!! I have already posted a WTB in the parts section. http://67-72chevytrucks.com/vboard/s...ad.php?t=72183 .
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 01-09-2015 at 12:35 PM. |
Re: Any one have a 1967 truck with 327 engine?
Even a bare block can provide provide helpful casting number and date information.
So please check your hoarded truck 327s. It is important to note for this truck it will be a 66 casting date (example L 10 6). Any 67 casting date (example A 13 7) or 68 C20-30 "YH" coded 327 engine would be incorrect.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 01-01-2015 at 09:59 PM. |
So far it appears based on what I have heard back in another post. That a 1967 1/2 ton (10 series) 327... would (so far) have the possible block casting numbers of:
3892657 3903352 - appears only to be used in Car applications, so this may not be accurate as it appear these blocks were cast in Tonawanda only, I am looking for a Flint Cast block.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 01-09-2015 at 12:37 PM. |
And...
Tim, correct me if I am wrong here, but I am looking for a Flint cast block that was cast in late Nov 1966 thru Dec 19, 1966. Correct? Are there any other specifics that play into things here? Or, is there a better way to narrow it down to a block casting number I may be specifically looking for, such as Flint Only cast blocks?
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
I think a buddy of mine just took a 327 out of a 67 c10. I'd have to look at the numbers to see if it's what you're after or not. The truck was cut in half to make a trailer a long time ago and he bought the front half at a farm sale about a year ago.
It's a shame they cut it up for a trailer. 1967 c10 air, tach, pb, ps?,big back window, and 3:73 posi. All the chrome. Was a nice truck.
1964 ![]() |
#6 | |
Kansas isn't a billion miles away from me either. I might be interested in anything else the guy may have left of the AC, PB, PS stuff also. also... I wonder if it was a TH400 truck. What we would be looking for is: Block Casting Number rear DS of block on top of trans mount area typically 7 digits. Casting Date Code rear PS of block on top of trans mount area, typically a letter followed by a few numbers, such as L 10 6 (Dec 10th 1966) Stamp Code on the front passenger side cyl head mounting surface pad just in front of the cyl head, just above the water pump mount. This will be series of numbers that will start with a few possibilities of letters; such a V, F, T, etc... followed by a date code of any where from 0101 to 1231 (I guess) 0101 being Jan 1st to 1231 being Dec 31st. Then typically followed by a letter or 2 or 3. So, example being: Block Casting number - 3892657 Casting Date Code - L 10 6 Stamp code - V1108ZA Thanks for checking into this for me.
#7 | |
Ok so i was able to run out there today and look at the grease ball. Lol. Cast number on rear of driver side are 3892657. Left front pad reads V0309YH. I didn"t look at the date code sorry. I'll post a few pics for ya soon.
1964 ![]() |
Here is some pics.
1964 ![]() |
Well, everything was ideal until the V0309YH I am hoping to find a V1210YH to V1220YH stamping on the front pad. But the 3892657 was correct as well.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 01-09-2015 at 02:44 PM. |
64shortbed... Call me please. I sent you a PM
![]() Join Date: Jan 2012
I have 0ne,but are you looking for information or to buy? I can post some pics,if you need casting #s I,ll have to do it when it warms up.Truck is outside and we're in the polar vortex.Ha!
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS ![]() |
#13 | |
Information I am looking for is. 1) I am trying to determine what 327 block casting numbers all came in a 1967 1/2 ton truck 2) Get an idea of block casting date (rear Pass Side of block on flange to transmission mount) in relation to engine assembly date / stamp code (front Pass Side by cyl head mount surface). So far I have found one that was cast on Nov 3, 1966 and assembled Nov 4, 1966. But is this typical or are there ones out there with a wider separation of these dates. 3) I also need this same info for cyl heads, intake, etc... such as what heads came on what block and how close are the casting dates to each other (block date to cyl head date) So, if I can find a few people with bone stock 1967 327's, then maybe I can get the block numbers, cyl head numbers, intake numbers, etc and have a pretty good idea of what I am needing to look for. Now, if that bone stock 327 has got the numbers, dates, etc that I would like to have and its for sale for a reasonable price and not 1500 miles away in the wrong direction, then I would be willing to buy. But mostly in this thread I am looking for info.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 01-10-2015 at 01:02 PM. |
![]() Join Date: Sep 2010
I am in on this also...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
#15 |
I posted my spid an rh frt block pad on another thread #18.SSTim decifered a few posts later. I will go out to see if I can get casting pics. FYI ( not for sale )
http://67-72chevytrucks.com/vboard/s...d.php?t=654110
#16 |
#17 |
So far that 3892657 is the most frequent block number to come up.
Your stamp code appears to be a V0303YR, which means: Flint, Mich - March 3rd - Powerglide. I am curious to see the block cast date (rear Pass side on trans flange) to see when the block was cast in relation to assembled (March 3rd)
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 01-10-2015 at 07:42 PM. |
#18 |
I am curious also to see if I have aa authentic 327cid 67 c-10. my sons jeep is in the garage at the moment,so it'll have to wait.I do know I have 2 different cyl.heads one has taper seat plugs the other is gasket seat. I had to trash the valve covers ,sometime down the road the valve covers got 8 cracks in the top of them.I don't know if it was high lift cam/rockers or what/
#19 |
I just picked up a 1968 GMC 1/2 ton long bed with a 327. The number on the front of the block is V0110YK.
1969 Chevy Long Fleet Custom C/10 (2nd owner) 1971 Chevy Short Fleet Custom C/10 (2nd owner) 2001 Chevy Silverado Ext Cab ![]() |
#20 |
give me a location 67 cst swb. I mean picture I have not been this deep into factory #. If it is on the side of the block the heater box is in the way!
#21 | |
If the engine is in the truck, then it may be hard to see the cast date numbers. As far as location. If you think of the location of the block numbers (3892657) the casting dates are opposite that on the passenger side. Although they will not be as large or as easy to read. These are the numbers/dates I am most interested to find on a 327 with 3892657 block numbers. Hoping to find a L 10 6 to L 20 6 casting date.
#22 |
I'll try crawling in there tomorrow.I'm interested also. I do know the powerglide is gone. had a turbo250 3spd when bought. I might be in the same boat only looking for a powerglide!
#23 |
![]() Join Date: May 2010
It's not a 327, but for those looking for the casting numbers here are pictures of the original 350 from my 69 that show the locations. The casting number (3932386) is on the left. The casting date (K278...Nov. 27, 1968) is on the right. My truck was assembled late the 2nd week of Dec., 1968.
#24 |
Thank you FirstOwner69 !!!
#25 |
I have one but it was born in 67 and it was a 4 speed
VO505YS 3892657 D177
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
