Re: Cool Craigslist Find
Weren't Mercedes diesel's known for being under powered?
Not a clue, it was local to me and if I didn't already have a fresh sbc I would go investigate. Seems the mileage would be good
Roadside Rebuilder
I've owned several MBZ diesels. The 3.0L (OM 617) is pretty quick with the turbo--all things being relative. You can fiddle with pump pressure a bit, though it's not really worth the time. I tuned mine for economy and enjoyed 27 mpg in a roomy, comfortable car that weighs 3500 pounds. Without a turbo, they're a bit of a dog, and the four-cylinder model (OM616) is laughably under-powered--I think around 70 hp...
What they are is damned near indestructible. The only real weak link is the timing-chain, and they only break when ran way past the recommended replacement time. I snapped one at 250K, and the cylinders made contact with the valves and blew my cam right off the towers. I sold the car off, and a friend of a friend bought a used head, a new chain and a tensioner, and drives my old 240D everyday, and that was years ago. Being as a Fleetside C10 weighs around 4500 pounds, I think the Benz Oliburner might be a bit underpowered, though fuel economy would probably still be pretty good. Also, the bulk of the US-Spec cars didn't have OD, so if you were to hook it up to something like a 700R4, or a T-5, you'd be laughing right past the gas station, unless you were heading up a hill. |
interesting...
i have seen 350's in the strangest places, volvo/volkswagon/fords neat to see it the other way around. |
Roadside Rebuilder
Those OM-series motors are an increasingly popular swap for all sorts of stuff.
Seen 'em in F100s, CJs, Landcruisers, Hilux/4runners, a Hudson, and a Range Rover. There's a few people making adapters now, mostly for Chevy and Toyota trannies, though a lot of folks--especially those running two-wheel drive--just use the Benz trannies. Both the manual and the auto are robust, and the auto features a rear-mounted pump, so you can pop-start the engine if your alternator dies. |
We have 5 sprinters in our Fleet any thing that says Mercedes I would run as far away as possible.
#8 | |
Roadside Rebuilder
The older stuff--while still spendy at times--is dead-simple mechanical-injection and a joy to work on. About as simple as it gets, hence they last 500K before any real work is needed, and 1,000,000K isn't unheard of. They powered reefer-vans for decades, and to this day, they're the Third-World taxi cabs of choice. The newer stuff? Listen to Bigsteve!!! Flee!!! Last edited by Oregoon; 01-05-2015 at 01:26 AM. |
![]() Join Date: Aug 2014
interesting find, but what I think is cool about these trucks is No German Engineering, and I speak from experience, you know their motto "Why make things simple when you can make it complicated!"
^ if you think MB engineering is complicated, you probably should stay away from anything BMW. Multiple redundancies everywhere.
I have an '85 MB 280LS, inline 6-cylinder. Dual overhead cam, lash-type followers. One of the simplest engines I've ever worked on and makes over 1hp/cu.in. in stock form. Sounds like a sewing machine when it's running. |
#11 | |
Roadside Rebuilder
