Old 01-03-2015, 12:27 AM   #1
64shortbed
64shortbed's Avatar
Replacement heater control levers?
Well I was playing with the ol 64 GMC tonight and broke the middle lever off at the knob. 😡 Well I was looking in classic parts and they have a steal set for around $37. Has any one used this set and are the better (as far as movement) the the original cast ones?
Honestly I've thought of welding hole in dash shut and going to some pull knobs. This isn't the first time it's happend and I only have one more original middle lever left.
64shortbed is offline   Reply With Quote
Old 01-03-2015, 01:19 AM   #2
64shortbed
64shortbed's Avatar
Re: Replacement heater control levers?
Other reason I've thought of putting pull cables in is so I can have controls closer to me. All you GMC guy know what I'm talking about. Having to reach across the dash to adjust heater.
Old 01-03-2015, 10:35 AM   #3
VonDog
VonDog's Avatar
I have to reach too which is a pain. When I got my truck, it came with a box of a few replacement parts and there were steel levers in there. I re-did my whole heater system and the steel works fine - probably stronger than cast. The older and stiffer cables need to be thoroughly cleaned and re-lubed cause they get really stiff and put a lot of stress on the cast lever causing them to break.
I think pull knobs would be nice but I want to keep my truck original
VonDog is offline   Reply With Quote
Old 01-03-2015, 03:28 PM   #4
64shortbed
64shortbed's Avatar
Mine are new cables when I built the truck. But I've broke this will make 3 center levers. I think it's because of the reach they push to one side and eventually snap the ends off. I've got it now where I can use the heater. But just tired of replacing levers. May just buy steel ones and hope they last.
Not to worried about stock on mine. 4 trucks in to one! 1985 suspension and rear end. 1982 350 with a late 70's 350 trans. Cab from one, frame and bed from another. Etc.... Lol
Old 01-03-2015, 04:31 PM   #5
1966shortwide
I have replaced my broken one's with steel and no more problem's . I took cable's out and lubed all ,will make them easier to use.
1966shortwide is offline   Reply With Quote
Old 01-03-2015, 10:37 PM   #6
chevy_mike
Never Ending Projects
chevy_mike's Avatar
There was a great write up on doing this recently and the thread got added to the FAQ listed at the top of the page. Here's the write up.
http://www.67-72chevytrucks.com/vboa...d.php?t=653541
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-12-2015, 03:17 PM   #7
64shortbed
64shortbed's Avatar
Well i did go ahead and buy the new steel levers. Works great.
