Old 01-05-2015, 07:13 PM   #1
'65 chevy lover
Speedometer/trans compatibility question
I have a '65 c10 with the stock speedometer and, I'm installing a TH400 trans. Will the speedo work correctly with the TH400?
'65 chevy lover is offline   Reply With Quote
Old 01-05-2015, 07:56 PM   #2
65sub
65sub's Avatar
Re: Speedometer/trans compatibility question
It should work ok. You might have to change the plastic drive gear in the transmission to make the speedometer accurate.
65sub is offline   Reply With Quote
Old 01-05-2015, 09:36 PM   #3
'65 chevy lover
"It should work ok. You might have to change the plastic drive gear in the transmission to make the speedometer accurate"
Thanks for the reply. What's involved with that and, where do I get the correct gear?
Old 01-05-2015, 10:15 PM   #4
Hugh in NC
Hugh in NC's Avatar
First you should know how many miles per hours the speedometer is off. Then you need to know how many teeth are on the current gear (also color). On my truck, reduction of 2 teeth changed the speedometer by 5 mph.
Hugh in NC is offline   Reply With Quote
Old 01-05-2015, 10:40 PM   #5
65sub
65sub's Avatar
Remove speedometer drive from the tailshaft housing. Colored plastic gear slides out. Your local transmission shop should have gears
Old 01-05-2015, 10:52 PM   #6
'65 chevy lover
Thanks Guys, appreciate it!
Old 01-06-2015, 01:39 PM   #7
61K10
61K10's Avatar
should be the same as it's been with the old trans if not an overdrive you are removing. that is if it was right to begin with.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
