Grill refinishing
Got a nice almost dent free 69-70 grill the other day that was sanded then painted. I've removed almost all of the paint with paint stripper and lacquer thinner. Looks like it was sanded with 80 or 100 grit paper prior to painting.
Were the original grills anodized? My winter beer-drinking project will be to wet sand the grill and polish it. Has anyone done this and how did it come out? Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
Re: Grill refinishing
It is very easy to polish aluminum, but you will have to get those nasty 80-100 grit scratches out. Try to get to at least 400 before you wet sand, but 1000-2000 would be ideal.
_____________________ '72 C10 Custom Fleetside ![]() |
Wow, that sucks that they sanded it. Best of luck with the sanding project but be careful as these things were thin from the factory and still dented easily so they need all the material they can hang on to.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
subbed
Figure out what you want--then figure out what you are willing to give up to get it. |
Post some pics when you get started on it ,would love to follow along as I have one that needs done .
Moderator
![]() Join Date: Jun 2008
Yes, our grilles were originally anodized or electro-plated. Once you polish the grille, you'll need to seal it. I stripped, sanded, and polished an aluminum part off of my Plymouth and found the polished effect to be very bright and mirror-like. The trouble with polished aluminum is that the aluminum, once stripped, is not protected and will need to be polished often. You may want to look into sealing it with a clear (not sure how it would turn out), but ideally, anodizing would be best and the most natural looking.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
if you have to remove that anodizing, use some "draino" crystals in warm water and use a paint brush to apply it, it will turn the aluminum a dark color as it removes the anodizing layer, don't over do it, but once the metals turns dark, you need to rinse very well and then dry it right away, then it's just a matter of sanding with very fine sand paper- 300, 400, 600, 800, 1000 grit,etc.... then use some jewelers rouge and a good flannel buff wheel to polish it out, you can get most of the polishing compounds at any truck stop, or eastwood,etc...Zaino makes a good sealer for polished aluminum... hth,
Ben ![]() Last edited by snipescastle2; 01-07-2015 at 09:23 AM. Reason: adding |
I stripped mine with oven cleaner to get the anodizing off, then I rubbed it with steel wool to get a "brushed" finish. I went over that with rattle can gloss clear coat, then painted the black parts back in over the clear. Its been a year and still looks good.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
Very good info so far everyone ,I have a very nice original 70 and 72 grill I want to do that on. Will make nice wall art .
Thanks for posting this question. I have a '72 grill I want to shine up too.
Great tips and ideas, thanks!
It has been too cold in the garage the last few days so I haven't started working on it again yet. I've got piles of 220 grit sandpaper so I'll start with that first. I learned in school that the best way to sand was to go 90 degrees from the previous grit to see that the scratches were removed. Not going to happen with the grill though since it is going to be awful tough to go side to side on those long parts. Paul
