Old 01-08-2015, 06:47 AM   #1
Mjminino
Inside the Doors.
What are y'all using to protect the inside of your doors? I'm about to redo the lower half of the doors. While I have it accessible I was thinking about using por-15 to about an inch above the opening on the door and and about an inch on the repair panels. Then when I'm about to weld everything together use weld through primer for those last 2 inches thatvare bare... Thoughts/opinions?
Mjminino is offline   Reply With Quote
Old 01-08-2015, 10:22 AM   #2
62 Barnfind
62 Barnfind's Avatar
Re: Inside the Doors.
I blasted mine, sprayed rustoleum rusty metal primer and semi gloss black to thew inside. Then I put the outer skin on. I figured I didn't have to go to expensive because it didn't have it before. So now it has some protection.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 01-08-2015, 01:15 PM   #3
65 C20
After you treat the metal with what ever you chose some people like to add some sound deadner while they are at it.
65 C20 is offline   Reply With Quote
Old 01-08-2015, 01:23 PM   #4
cg285
body schutz
cg285 is offline   Reply With Quote
Old 01-08-2015, 03:13 PM   #5
65 C20
Originally Posted by cg285 View Post
body schutz
I just goggled body schutz by 3M.
That looks like a good product that will seal and sound deaden all in one.
Old 01-08-2015, 04:28 PM   #6
Mjminino
Wow! They're mighty proud of their Applicator gun! 90$!!!
Old 01-09-2015, 01:38 PM   #7
65 C20
Check 3M 08964
Comes in an aerosol can also.
I haven't tried it but if you are only doing 2 doors should be enough.
