The 383 stroker so far for my 69 C20
.030 over 1969 010 four bolt main block with ARP main studs
SRP forged short skirt pistons 6 inch Eagle SIR rods Stock 400 crank Melling high volume oil pump Lunati nitrous cam .520/.509 lift with 234/244 @.050 on a 112 LSA Canton 7 quart oil pan Moroso Re-enforced timing cover ![]()
69 ![]() 63 Buick Rivera 407 Nailhead TH400 |
![]() Join Date: May 2013
Re: The 383 stroker so far for my 69 C20
Thats alot of cam ,,,,, what heads
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
Dart sportsman 200 cc runners, ported, 2.055 & 1.625 valves.
I must have started a trend! I put dart heads on my 350 small block
.................._____ __________//___{\____ /__---____//____/__---/ .....(O). ..................(O). BUILD THREAD K20 http://67-72chevytrucks.com/vboard/s...d.php?t=651601 pages 2-4 ![]() |
#5 | |
![]() Join Date: Jun 2014
Whats your HP goal? |
Excellent choice for heads , should work great with your engine
That's almost the same cam/set up I'm runnin. I chose AFR heads for my rig. Can't wait to hear it rumble. AFR has dyno sheets around the 475 hp mark with that setup. Good choices there IMO.
Are you running a flat tappet cam? I'm assuming so based on the block. Why not a roller cam to go with all of the other goodness you've assembled? Not knocking your set up, just curious.
I figured i will run this flat tappet until i get tired of it. I will put a roller cam in when the engine comes out of the truck for a freshen up.
We're thinking around 440 hp and close to 500 ft lbs.
![]() Join Date: Nov 2006
What does it cost (if I might ask) up there in Illinois to have the mains honed for the studs?
Line boring?
have you measured the bores on the main bearing saddles? measure them with the bolts torqued up and then with the studs , if there is a difference then get it line bored, more than likely there will be no difference.
GMC K1500 1971 350 cu in th350 4wd Bondo Bob c 10 1971 stepside th 350 c10 1970 350 cu in manual air con stepside. |
The mains were twisted from the studs, no line boring, but a line hone was recommended. Only ran me 100 bucks.
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Nice! What tranny and rear end?
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
#15 |
Doug Nash 5 Speed, and a Dana 60.
#16 |
Truck currently has a th400 and a Eaton HO72. Nash and Dana are being built.
