Old 01-11-2015, 09:47 PM   #1
trb0613
trb0613's Avatar
Drop spindle/caliper issues
This is my first post and man.... I have problems. Im in the process of installing some 2.5 " (1.00") CTS drop spindles that I purchased off ebay. When I installed the spindle and rotor, I noticed that the caliper would not bolt on correctly. After some trouble shooting, I just screwed in the caliper bolts with just the rotor on the spindle and the screws are rubbing the rotor? Has anyone had issues with the two threaded holes on the spindle being off?
trb0613 is offline   Reply With Quote
Old 01-11-2015, 09:57 PM   #2
J Knight
J Knight's Avatar
Re: Drop spindle/caliper issues
It appears you either cross threaded the caliper bolt or the hole was tapped crooked by the manufacturer.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 01-11-2015, 10:52 PM   #3
trb0613
trb0613's Avatar
I think that the holes are not tapped square as well. I didnt know exactly how much space should be between the bolts and the rotor.
Old 01-11-2015, 10:15 PM   #4
bbbc10
Diggin The SquareLife
that sucks an that's why u don't buy cheap off brand junk off ebay
bbbc10 is offline   Reply With Quote
Old 01-11-2015, 11:44 PM   #5
DREAMER1
DREAMER1's Avatar
Take em to a machine shop along with your old set. They'll fill and re drill the holes. One of Mine was cross threaded. I think $45...
DREAMER1 is offline   Reply With Quote
Old 01-12-2015, 02:14 PM   #6
77c10
77c10's Avatar
Contact the seller from eBay and ask them to make it right.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 01-12-2015, 04:17 PM   #7
Bigstevex4
Bigstevex4's Avatar
Just put some on you need to trim square cast piece on caliper no big deal look on bottom inside cut corner off. wont let the caliper move in enough why cockeyed in the hole.
Bigstevex4 is offline   Reply With Quote
Old 01-12-2015, 04:45 PM   #8
Bigstevex4
Bigstevex4's Avatar
That little cast knob and a cut off wheel just cut corner right bottom.
Old 01-18-2015, 12:50 PM   #9
trb0613
trb0613's Avatar
Thanks all for the feed back. I solved the problem with the misaligment, the brake line was against the upper control arm. I turn the line slightly. The spindles are casted with excess material causing the caliper to missalign. so out came the grinder, chased the threaded holes and boom... everything fit properly.
Next issue is after installing drop spindles with factory springs with 2 rounds cut out, the truck is in the weeds.
Old 01-18-2015, 02:02 PM   #10
J Knight
J Knight's Avatar
You should have only cut ONE round off the stock springs.
With 2 rounds cut and drop spindles your tires must be hitting or even resting on the inner fenders as well as your lower control arms practically touching the ground.
John
Old 01-18-2015, 02:54 PM   #11
trb0613
trb0613's Avatar
Correct. That's the new issue. Originally, I was hoping to get enough drop without buying spindles. Now I need new springs.
Old 01-18-2015, 03:08 PM   #12
Malo83
Cruzzzn' Vet
Malo83's Avatar
Back in the day they used a 1/2" spacer and longer Aarm bolts to kick the top of the tire back out, The Drop Shop in LA dropped my 83 with this kit when going with 2 cut coils, still running this setup 32 years later
Malo83 is offline   Reply With Quote
Old 03-12-2020, 07:24 PM   #13
thirstybob
This really helped me today. Thank you! Just did this, 3" drop spindles from Switch and 2" lowered springs. I had the stock calipers with a 90 right before the banjo bolt which caused the brake line to get hung up on the inside of the upper ball joint. You helped me fix it.
thirstybob is offline   Reply With Quote
Old 01-18-2015, 01:06 PM   #14
lolife99
67-72 parts collector,…
lolife99's Avatar
You might have issues getting the front end aligned with two coils cut.
Keith
Convert to disc brakes.
Old 03-18-2020, 06:59 PM   #15
MikeB
MikeB's Avatar
No-name eBay stuff scares the crap out me, especially steering and brake parts that can kill you if they fail. Such is the case with cheap non-USA built steering columns and Pitman arms that have poor welds. Heck, some countries have outlawed the importation of certain Chinese car parts.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
