Old 01-12-2015, 05:05 PM   #1
no1udknow
no1udknow's Avatar
late 90's vortec 3500 ?s
I'm sure someone has done this swap. Ls packages are fantastic, but also spendy, how different is the vortec 350 block from the older 350 sbc's I feel like these engines are readily available everywhere, I can pick up a late 90s tahoe for under 1000, and my 96 tahoe seemed to have a lot of power. any input is apreciated thanks.
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 01-12-2015, 05:11 PM   #2
no1udknow
no1udknow's Avatar
Re: late 90's vortec 3500 ?s
side note, I was reading about the vortec 5700 (350) on wikipedia and started laughing when I saw this little tidbit....
Special applications
Oscar Mayer Wienermobile
Built not bought!
Old 01-12-2015, 05:12 PM   #3
dubds10
Stalker Nate
The nice thing about the '90s Vortec engines are their heads and roller rockers. Great to build up for power and easily carb'd if that's what you plan on doing instead of running all the computer stuff.
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
Old 01-12-2015, 05:28 PM   #4
MARKDTN
Yes, you can do this.
5.7Vortec/4L60E or 4L80E harness are available from places like Street and Performance or Howell. You will have to have your PCM reflashed. Use the Vortec belt system and alternator. Find a compressor delete if you aren't going to have a/c. Should bolt right in and use standard mounts and exhaust, also hoses and fan shroud should work although it is a "long" type water pump.
The weekend after I put the Tuned Port engine in my '83 K20, I drove a '99 3/4 ton GMC and am pretty sure it had more power than my swap I just did. Have to be careful about intake leaks. The later were better, but there are issues with intake leaks on these getting water in the valley which can be detrimental. I think '96-97 are particularly bad about it. Anything I bought, I would put intake gaskets just to be sure.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 01-12-2015, 06:04 PM   #5
57taskforce
All about them K’s
57taskforce's Avatar
I would say the difference in the power you felt is the vortec heads ability to generate low rpm torque. That's kinda where they are the happiest. The don't flow near as well at high rpms in my expierence.
Tyler
Old 01-13-2015, 08:44 AM   #6
MARKDTN
Yes, but low end is where a Tuned Port shines as well. I am really happy with my TPI. The visual of a TPI is the best of any small-block ever IMHO and they are quite reliable.
I hope the OP is going to keep the injection and electronic transmission. I would not go to the trouble of putting one in without fuel injection. One of the reasons the fuel injected engines go so many miles is that you aren't getting as much fuel in the oil as a carbed one.
If you do carb it, I would be cautious of the advice above. The Vortec heads will only stand so much cam without some machine work. The valve springs will bind. You really should get the right distributor gear, or you may have trouble. '90 Corvette and '90 IROC Camaro are 2 different IDs on the gear. One or the other should work. I am unaware of any differences in heads between 4x4 and 4x2 applications.
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 01-13-2015, 09:39 AM   #7
Mock1
I was only stating my experience with what ive done, not what he should do. I also stated the rotating assembly speced out, so I used the stock cam, standard bore block with stock rings, and stock pistons.
I have two different distributers, factory HEI, and a MSD Pro Billet, both gears were IDENTICAL to the gear Summit sold me for a roller cam. And it wasnt for a corvette or a camaro.
Ive opened six 4x4 350s in the past year and they all had swirl port heads, maybe a fluke, dont know. I just assumed they all were. My bad.
Mock1 is offline   Reply With Quote
Old 01-13-2015, 11:04 AM   #8
57taskforce
All about them K’s
I agree 100% the tpi motors are very Purdy! They were certainly the bees knees in there day. Also I would keep it efi as well. If you run the 0411 PCM there's a lot of potential for tuning and more power.
Tyler
Old 01-12-2015, 05:30 PM   #9
57taskforce
All about them K’s
I think you mean roller cam. I'm quite certain the l31 never came with roller rockers from factory. Roller rockers came with the Ls motors. The vortecs are certainly much closer to the small blocks we all know compared to the Ls motors. Inu opinion they are super reliable. Most of them have gone well past 200000. The electronics are still somewhat simple and the parts are available and relatively cheap. They have a few quirks like leaking intake gaskets but they are a good cheap option for a swap. Like any other original style small block look for worn bearings, blown head gaskets,etc.
Tyler
Old 01-12-2015, 05:46 PM   #10
dubds10
Stalker Nate
Yup didn't catch myself there lol Roller cam not rockers.
Old 01-12-2015, 05:37 PM   #11
Nitis
Nitis's Avatar
Fwiw. I'm pretty sure the vortec 5700 is one of the first LS that was a 5.7 l like from the gto vette etc
You are referring to the L31 the knock on them has been the injection style I'm not an expert so don't ask me for specifics. Also some claim the heads to be on the weak side but they do produce flow for sure. One perk people like is the one piece rear seal
I'm sure 15 years ago this was a much more popular swap but the LS is so much more readily available. But not practice in all applications like my 72 4x4 requires some extra effort
I'm seriously leaning towrds a stand alone TBI myself for pure simplicity.
Nitis is offline   Reply With Quote
Old 01-12-2015, 05:54 PM   #12
57taskforce
All about them K’s
I've always understood the Vortec designation to be a truck thing as far as I'm aware(even though the Ls car and truck motors are pretty much the same with small changes like intakes and such). At least on the late 90s stuff I know it's true. The cars had the Ls1 but I don't remember them being called a vortec 5700. Are the current car motors called vortec 5300 or similar depending on displacement? I genuinely don't know because I'm into stuff that's 15+ years old for the most part.
Tyler
Old 01-13-2015, 12:40 AM   #13
no1udknow
no1udknow's Avatar
Yeah, I know about the spider injection system and it's flaws, had that problem on my tahoe. they weren't too bad to change. Anyone souped one up, what kind of power have you gotten out of it?
Built not bought!
Old 01-13-2015, 04:22 AM   #14
mechanicalman
The L31 heads got a bad rap for being weak and cracking IMO because people were installing them without any t-stat bypass hose. They simply do not have that hole drilled to match up with the block and when installed without a bypass hose the coolant does not circulate until the t-stat opens and sits there and burns atop the cyl head creating steam pockets and eventual overheating and cracking.
I like your idea for the stand alone TBI. The wide band O2 systems are great and somewhat self programming.
Have you seen the stand alone fuel rails for the LS engines? Simply elegant.
mechanicalman is offline   Reply With Quote
Old 01-12-2015, 07:47 PM   #15
dirtyjim
dirtyjim's Avatar
actually the best donors come from 2001-2002 express vans. they used the 5.7 vortec with a 411 ls pcm. you can use the stock vortec central port inj or repin it for individual injectors and run a tpi style intake or a ramjet with a ls throttle body.
I'm collecting the parts to do mine now.
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
Old 01-13-2015, 02:19 AM   #16
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Good info. Can you elaborate on how to run individual injectors and where to get the parts to do the swap?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 01-13-2015, 12:52 PM   #17
no1udknow
no1udknow's Avatar
The original spider injection system that came on most of these models was a single piece, which meant that if an injector went out, (and they usually did from what I have read), you had to replace the entire unit. However, most parts houses now sell a unit with where the individual injectors are removeable. I had to do the one on my tahoe, luckily the unit had already been replaced so I only had to buy a couple of $65 injectors rather than the $400 complete unit.
Built not bought!
Old 01-13-2015, 09:34 PM   #18
dirtyjim
dirtyjim's Avatar
basically your combining parts from both the vortec black box style harness and the ls based 411 harness. if you start out with the 2001-02 express van harness you will need to get the injector harness from a ls engine then repin it to the express van haness.
if your repining the 96-2000 black box pcm harness for the 411 pcm swap you will need to get the injector harness when you pull the 411 pcm from the salvage yard.
old school efi makes a stand alone 411pcm vortec harness for around $600 or you can google 411 pcm swap the find a guy who goes by lextech on most forums and get the pinout from him
just research 411pcm swaps for a few days and you should be able to find plenty of info on them
Old 01-12-2015, 08:30 PM   #19
Eddie H.
Eddie H.'s Avatar
As mentioned, the L31 vortec engine has many desirable features like a roller cam and one piece rear main seal. The swap is easier than with an LS engine, because except for the front serpentine belt accessory drive setup, the L31 is basically the same as the 350 that came in these trucks originally. They did have a problem with intake gaskets leaking coolant into the crankcase and wiping out the bearings and the "poppet valve" style injector spiders also gave some trouble, but can easily be upgraded to a spider that uses individual injectors.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 01-13-2015, 12:58 AM   #20
no1udknow
no1udknow's Avatar
thanks for the input. I have been racking my brain over an ls swap, but the cost point and the amount of work involved in the swap alomost makes it not worth while. My tahoe had tons of power top end as well as some grunt, but I'm sure that could be adjusted through the various cams available for that motor. As far as the injector and intake issues go, I imagine someone makes aftermarket everything to solve such issues. I want good power, with fuel injection, and a good tranny and it seems the only way to get that setup is with a newer engine setup.... but I can't afford the ls option, at least not for a while.
Built not bought!
Old 01-13-2015, 01:06 AM   #21
87Skier
87Skier's Avatar
They are very similar. I just did this swap on my 72 GMC Jimmy since it needed a motor anyway. I liked the idea of having a carburetor, older style HEI, and running without a computer. If you go this route the setup is nearly indistinguishable except to the keen observer.
Some key differences, some already listed, one piece rear main seal, different timing cover, timing chain is a single roller (makes room for the crank angle sensor in timing cover), roller cam/block, and no where for a fuel pump in block, different valve covers and geared starter.
When I did my swap I bought a 97 Suburban for $600, threw on some new parts and it went right in. While I was at it I decided to do a bunch of other extra work. I swapped to an electric cooling fan (I think you can use the mechanical even from the new engine), used the new power steering pump (just swap the fittings from old pump to new style pump), and some other stuff.
This is my L31 swap
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 01-13-2015, 01:06 AM   #22
Nitis
Nitis's Avatar
If you don't mind me asking what's your budget? And what's it going in? Sure you can get late 90s tables for under a grand but they're pretty used up over 200k on the ticker right?
I just abandoned the thought of doing an LS swap on mine mainly because it's a 4x4 requiring crossmember swap and suspension lift. All things that kept stretching the required budget not really out of reach but to the point it would take me longer to finish the project than I wanted.
When I do add fuel injection down the road it will be tbi I'm almost certain unless I stumble upon some I found wealth
I passed on a wrecked 2003 tahoe 5.3 with 150k for 1300 the other day. If I had a 2wd I would have found my donor
Old 01-13-2015, 01:10 PM   #23
no1udknow
no1udknow's Avatar
My budget is cheap as possible. If I buy an ls motor, it will likely end up in my 2001 sierra... I have had a hard time finding an ls complete package for under 2k in my area. And that is for a wrecked truck/van that has over 100k on it. I can find a running registered truck/tahoe/van with a 5700 in it for 1000, yank the power train and sell the rest. Either way i will be pulling the motor apart and doing some refreshing/inspection/installing, but the price point to start is a lot better with the late 90's stuff and I get true closed loop FI. I have had a number of vehicles with TBI and I wasn't overly impressed.
Built not bought!
Old 01-13-2015, 01:27 PM   #24
57taskforce
All about them K’s
I say go for it. I havnt messed with a 5.7 in a few years but I've got a vortec 7.4 in my dd truck (granted the injection system is a bit different) I've had for 10+ years and I've always loved it. I've had a few suburbans with the 5.7 and was happy with them as well. For the price compared to an Ls swap it's hard to beat. Sure there's trade offs the Ls motors have more power potential due to their head design and flow but this is a great alternative to get proven reliable fuel injection, and serpentine. I think it's a great idea. Freshen it up where needed and let it eat!
Tyler
Old 01-13-2015, 01:13 AM   #25
Nitis
Nitis's Avatar
Of course if your going carbed no quirks no frills like the guy above 87skier
