Old 01-13-2015, 09:08 PM   #1
Bainsy
Bainsy's Avatar
Wiring harness seal help
hi guys im wanting to know where I can get a new seal for where the main wiring harness plug comes through into the engine bay? are they available online? im located in Australia but im willing to ship from the US
1980 C10 SHORT BOX 454 THUNDER DOWN UNDER!!!
Bainsy is offline   Reply With Quote
Old 01-13-2015, 10:33 PM   #2
83swb
Re: Wiring harness seal help
I thought they just used that nasty clear urethane to seal them up, but I may be wrong.
83swb is offline   Reply With Quote
Old 01-13-2015, 10:39 PM   #3
Bainsy
Bainsy's Avatar
this one had what looked like foam with adhesive both sides and when i separated it from the wall it tore all the foam up. it was cut perfectly to fit around the plug so im 99% sure its a factory thing.
Old 01-13-2015, 10:45 PM   #4
83swb
You may be able to replicate it with some double sided 3M or comparable tape.
Old 01-14-2015, 01:55 AM   #5
craig113
http://www.amazon.com/s?ie=UTF8&page...3Abutyl%20tape
I have used this to seal AC, windows, walls in the shop, grain bins, keeps moisture and a good air seal
84 K30 CC LB Fleet side 454/400/205/14 bolt Rebuilt 2200 miles
91 K15 Z71 SB 350/700r/241c/12 bolt 372k miles
96 K15 Sub 350/4L60/243c/10 bolt 333k miles
craig113 is offline   Reply With Quote
Old 01-14-2015, 02:30 PM   #6
mrolds88
Bainsy, heres a cheap possibility for you. I have gotten foam that was used for wrapping parts that would work well. Its about 1/8" uncompressed and would probably take a non petroleum sealer well. This is an example of what I am talking about.. http://www.ebay.com/itm/25-X-12-X-1-...item43d5efa290
I'm sure that you should find some locally.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
