Old 01-13-2015, 11:27 PM   #1
1moretoy
rear end markings
Can anyone tell me what this means. It is on the center section on the rear end. Truck is a 70 short step. Thanks
1moretoy is offline   Reply With Quote
Old 01-14-2015, 08:18 AM   #2
Mike C
Mike C's Avatar
Re: rear end markings
Just part of the casting info. Obviously General Motors and the 55 could be an alloy code or an internal date code or foundry code.
Doesn't mean anything. You can find stamped numbers on the passenger axle tube on the top side near the center section which do mean something, although many times what they book says doesn't jive with what you have IME.
If you are trying to figure out gear ratio and if you have a limited slip, the truck probably needs a gear oil change so your best bet is pull the cover and kill two birds.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-14-2015, 12:17 PM   #3
michael bustamante
michael bustamante's Avatar
is that a crack in the housing?
1967custom
michael bustamante is offline   Reply With Quote
Old 01-14-2015, 05:03 PM   #4
Mike C
Mike C's Avatar
Looks like the reinforcing rib and a shadow from the flash.
44 Willys MB
52 M38A1
64 Corvette Coupe
