01-15-2015, 10:21 AM | #1 |
Wheel spacers?
I need to get 1/4 inch wheel spacers for the front wheels to clear wilwood brake calipers. I was wondering if I do that would I need to buy new lug nuts that have a shank on them or be able use the ones I have? I have Camaro Rally wheels on my truck.. Also if I do need lugs with a shank on them do I need to drill the holes out bigger? Hopefully some one has ran into this problem.. Thanks -Mike
01-15-2015, 10:44 AM | #2 |
Re: Wheel spacers?
if the current camaro rally wheels do not need a shank style lug, you're probably ok with re-using them, provided you can still get at least 5 turns on the lugs after you add the spacers. Plus, if you get a good hub-centric spacer, there will be no room for the extra shank in the wheel stud holes
* Call me NOT the website number* Justin Novick (773) 303-8251 Sales/Support Entropy Radiator / Engineered Cooling Products "The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com |
01-15-2015, 11:07 AM | #3 |
Re: Wheel spacers?
I had the same problem with 5/16 spacers. Nearly. With the spacer on, the center hub ring does not seat leaving the wheel to be held in place by the lug nuts only. I was uncomfortable with this and took the spacers off. Perhaps I was being over cautious.
4oldcars Driving: 1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado The ones I let go: 1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed |
