Custom rear axle width recommendation.
I'm converting my 68 SWB narrow 12 bolt rear to the CPP big brake package and 5X5 lugs along with a 4.5/6 static drop.
I also plan on buying some BOSS 338's 20X8.5 F, 20X10 R wheels in the near future. Ive also read through the 338 thread.... http://67-72chevytrucks.com/vboard/s...d.php?t=352320 Seams like the rear offset on the 20X10's is 5.5 BS and most guys with the narrow rears are running spacers. Mark Williams Enterprises ( MWE) is right down for the road from me so I don't have to deal with shipping issues/cost. I think I'm going to have them install the weld-on housing end kits, dump the C-clips, and cut some axles for me. Then I can drop in my eaton posi/3:73's! I have the option of having MWE widen the rear end assembly while they are at it. It seams cheaper to do this while I'm at it that a custom set of wheels. any suggestions on over-all width? |
Re: Custom rear axle width recommendation.
Billet specialties will build you wheels with any backspacing you want and then you wouldn't have to modify the rear end.
![]() Slammed 53 5 window Blown/Bagged 54 Pickup Patinaed 67 LS stepside Supercharged 67 Nova Bagged 69 Suburban Turbo'ed 5.3 LS |
I knew that was an option too but $850 for a set of Boss 338 wheels or $2K for a set of custom set of wheels. For the difference, I can have a solid 12 bolt rear end build that eliminates the c-clips, rolls on a better bearing design, has no "end play" and allows me to mount ANY brake I want onto it while not having to rely on a big back space wheel w/ spacers.
I may go slightly wider than the 71' up 57" width. |
Buy wheels and tires. Pull axle from truck. Put wheels underneath truck and move them to where you want them to sit. Measure between wheels. Have axle made that width. Done.
Increasing axle length will do you no good with out increasing the housing length. I already checked if they could make the ends thicker, but they are pre forged at a certain thickness. These aren't driveshafts.
For some reason, I misread what you were trying to do. Been reading too many big tire/narrowed rear end threads!
I bought a Craigslist rear for my truck from a '72 Chevy. My truck is leaf spring so it was harder to find than a coil spring rear. The advantage of this for me is it came with all the brake parts as well. I swapped my posi into the new housing and just double checked backlash. From a dollars & sense standpoint, a used rear is the way to go. Depending on the housing ends that they have, they might be able to widen your axle. But you are going to have a ton of money in what is really a stock later model axle.
PITbut
Sounds very easy. Where do you get the housing and the axles cut to length? Or order from a place that does it?
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! ![]() My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
#8 | |
That's exactly what I did. For $1200 parts/labor it will be completely set up. Since my stock rear end is 55.5" and the later units are 57", I figured 57" was spot on. But w/o the wheels/tires, I was deferring to someone with experience here who could chime in if I'm out of line ( given the wheel choice).
