Old 01-16-2015, 04:26 PM   #1
Eraser475
Eraser475's Avatar
6.2 Diesel Cruising RPM's
I am trying to figure out a ballpark figure about what my RPM's are at when I'm going 60. I have tried this: http://www.dieselhub.com/tech/rpm-calculator.html , and it gives me around 1500 RPM. This seems really really low. I have a 6.2 Diesel, 700r4 transmission, 3.08 rear end, and 29" Diameter tires. Can anyone give me a figure at about what I'm currently at RPM-wise?
Dad's: 1973 Chevy C-60 Grain Truck 366 Big Block
Dad's: 1982 Chevy Silverado 6.2L Diesel K-10
Dad's: 1987 Chevy Silverado TBI 350 R-10
Dad's: 2007 GMC Sierra Classic 2500HD SLT
Mine: 1982 Chevy Silverado 6.2L Diesel K-10
Eraser475 is offline   Reply With Quote
Old 01-16-2015, 07:01 PM   #2
Oregoon
Roadside Rebuilder
Oregoon's Avatar
Re: 6.2 Diesel Cruising RPM's
Diesels are low rpm motors. I'd guess that figure is pretty close to accurate.
Does it sound like it's lugging?
Oregoon is offline   Reply With Quote
Old 01-16-2015, 09:02 PM   #3
Steve-W
Steve-W's Avatar
Yep seems perfectly normal to me.
My daily is an Audi A4 with a 2 liter diesel engine and a 6 speed manual box. At 60 mph it runs 1300RPM's in 6th gear ��
Feedback is always welcome!
projects:
1969 Chevy C10
1950 GMC 100
1958 Chevy C60 Viking ratrod
Steve-W is offline   Reply With Quote
Old 01-16-2015, 09:58 PM   #4
68Timber
I know the pieces fit
68Timber's Avatar
This is the one I usually use: http://www.wallaceracing.com/gear-speed.php
It agrees, 1500 rpm at 60. It also lets you plug in other rear gears to compare.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-16-2015, 10:01 PM   #5
Corts60
Just here to tinker
Corts60's Avatar
You want your engine to be at peak torque when cruising to achieve the best MPG.
Peak torque on a 6.2 is around 2,000 RPM.
Old 01-16-2015, 10:14 PM   #6
rs74
rs74's Avatar
So with a lower gear he should see better MPG's then? You would normally think that with a higher gear it would get better mileage. Maybe more so if it was a gas engine.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 01-17-2015, 10:16 PM   #7
Dieselburb86
My dad has an 86 GMC with the 6.2 and 3.42 gear ratio! I got 21 mpg cruisin down the highway. BTW it was a 2wd suburban.
Dieselburb86 is offline   Reply With Quote
Old 01-18-2015, 05:45 AM   #8
Edahall
I've got the same setup as you and best fuel economy is 55 mph. 65 mph is the point when fuel economy starts to really plunge. The lowest I have ever got was 17 mph driving between 85 and 95 mph. About 10O mph is terminal velocity on one of these things.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 02-03-2015, 02:21 PM   #9
slotard
You managed 17 at 85-95? That's pretty impressive. I don't think I could even approach that at any speed.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 01-18-2015, 05:50 AM   #10
Edahall
If you're on a really tight budget, keep it at 55 mph. At 70 mph vs 55 mph, you'll burn about 20% more fuel but of course get there a bit faster.
Old 01-18-2015, 12:05 PM   #11
Eraser475
Eraser475's Avatar
Why does it just drop so quickly? Is it because resistence increases as speed does?
Old 01-18-2015, 05:01 PM   #12
Edahall
The answer to your question is poor aerodynamics. Remember, these vehicles were produced when the maximum speed limit was 55 mph. The worse the aerodynamics, the faster fuel economy will drop off with speed. It'll also limit top speed.
Old 02-03-2015, 11:49 AM   #13
rs74
rs74's Avatar
Let me ask this question. This diesel I just bought came out factory with 3.08's and 235/75's with is a 28.9" tire. If I put a smaller diameter tire on then wouldn't that effectively lower the effective gear ratio. Does that make since. I used a gear ratio calculator and it was saying that if I put on a 27" tire then it would change the effective ration from a 3.08 to a 3.3:1 ratio. I realize the gears are still 3.08 but the overall ratio would change with a small dia. tire. Right?
I was thinking about lowering my truck and putting a smaller tire on. So if I do that then I can get closer to the 3.42 ratio that is suggested would give me better mileage. Hope that all makes since.
Roy
1987 R10 shortie
Old 02-03-2015, 02:22 PM   #14
slotard
They were designed before the 55 national limit. That came into effect in 1973, I'm pretty sure the design work was finished before it.
1973 C20, 350/350
Old 02-03-2015, 11:54 AM   #15
rs74
rs74's Avatar
http://www.jeep4x4center.com/calculators/?utm_source=cj
Roy
1987 R10 shortie
Old 02-03-2015, 12:02 PM   #16
Bigstevex4
Bigstevex4's Avatar
Some thing else people dont take into acount epesialy with high comprestion long stroke diesiels. I s the amount of Horse power it takes just turn the eng at say 3000 rpms. theres a point when your eating up power your making.
Bigstevex4 is offline   Reply With Quote
Old 02-03-2015, 12:29 PM   #17
nonstop
Just throwing this out there - what about throwing a turbo on there? It will give an all around increase, and used units can be found for the price of a moderately priced set of tires. Never did one on a GM, but woke up my 6.9.
nonstop is offline   Reply With Quote
Old 02-03-2015, 03:03 PM   #18
crashz
crashz's Avatar
To the OP,
One thing to keep in mind driving an older square some distance is to check/change all fluids and filters. I did the same thing you are, only 1/2 the commute (3 hrs), on a weekly basis and quickly realized why you need to check the fluid in the rear axle. Burnt up the pinion bearings.
Mine was an 83 K25 (different from my sig) with 3.73 gears (I think), 6.2L diesel, and th350 trans. At 70 she was at top speed, but ran happily for years with my foot on the floor. It was a nice old truck, but rust had taken her at a time when I was in school and could not fix her.
One thing I like about the 6.2 is that they smooth right out on the highway. Mine always seemed to run best on the highway at a constant speed. Always loud, but happy
2012 Chevy 2500HD, 6.0L, 6spd auto, 4x4, ECSB
1987 GMC V3500 Dump, 6.2L diesel, TH400
1983 GMC K2500 - awaiting its restoration and Cummins swap.
crashz is offline   Reply With Quote
Old 02-04-2015, 10:34 AM   #19
D13
D13's Avatar
Remember a 3.08 with overdrive is like a 2.56. Having said that, my 87 gets best MPG at 58 (fast enough to keep the converter locked on little hills) and really doesn't care to go much over 70mph (quite frankly the truck itself is the limit not the motor).
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 02-05-2015, 12:29 AM   #20
Edahall
Keep the 3.08's for top cruising speeds and to pass other much newer SUV's with 95 mph limiters.
Old 02-05-2015, 08:18 PM   #21
Oregoon
Roadside Rebuilder
Oregoon's Avatar
Where on earth are you going a diesel-square that requires speeds in excess of 90?
Old 02-05-2015, 08:42 PM   #22
Corts60
Just here to tinker
Corts60's Avatar
Old 02-05-2015, 08:53 PM   #23
greg64
greg64's Avatar
X2. Zombie apocalypse?
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
