![]() Join Date: Jun 2012
Tremec T56 Magnum 6 speed transmission
SOLD
This was the Elite T56 conversion kit bought from Hurst Driveline Conversions. Brand new no fluids have been put in this transmission. Bolted to motor and set in frame is all that I have done with this. Gear Ratios: 1st 2nd 3rd 4th 5th 6th Reverse 2.66 1.78 1.30 1.00 0.80 0.63 2.90 Included: Needle roller pilot bearing - chevy Magnum T56 & Mopar TKO electric speedometer/VSS connector kit. WPT-589 - Pigtail harness F2UZ7H183 - Plug Retainer bolt and washer Instructions T56 reverse lock solenoid pigtail connector for Magnum & LS T56 T56 reverse light pigtail connector for Magnum & LS T56 Energy Suspension olyurethane transmission mount Porterbuilt Transmission crossmember. White 6-speed Hurst shift knob with chrome shift stick Flywheel bolt kit for LS motors Aluminum bellhousing for GM T56 Magnum to LS motor LUK clutch and flywheel kit for LS motors - 500HP Clutch and flywheel alignment tool 12561465 - LS pressure plate bolt set Extra added on: LS T56 Magnum hydraulic throw out bearing kit with 3/4" bore compact master cylinder kit with remote mount reservoir. Includes all other hardware This is going to include shipping without a lift gate service and would be to a business address that will be able to unload it. If other services are required I will revise the price to add in lift gate service or leave at dock fees. I also have a fortlift to load if this is picked up. I can also deliver this for a much smaller fee if it is within a 100 mile radius of 72758 zip in Arkansas. Price WITH shipping is $3500.00. New price $3400.00 Price with OUT shipping is $3200.00. New price $3100.00 Last edited by 1968Mann; 01-31-2015 at 04:17 PM. |
Re: Tremec T56 Magnum 6 speed transmission
New price.
What did you replace this combo with ?
