![]() Join Date: Dec 2014
C/30 rear wheels locked up, no fluid
So I'm starting to work on my grandpas '70 C/30 dually that has been sitting for years so I can get it running again.
Front wheels spin freely when jacked up in the air. I then jacked up the rear axle into the air and neither side will spin or budge at all. The brake pedal goes all the way to the floor with no resistance. I even had the truck idling, (rear axle airborne sitting on jack stands) and the engine would stall every time I tried to put it into 1st and make the wheels spin. That's how stuck they are! Here's a pic of the master cylinder when I took the cap off. The empty part is for the rear brakes correct? If so, why would the rear wheels be frozen when there is no brake fluid being fed to them? ![]() ![]() I'm not very familiar with brakes so any help is much appreciated. Does it look like I need a new master cylinder? Or should I just try bleeding the rear with fresh fluid? I was planning to pull the wheels off tomorrow and bang on stuff and see if the drums will break loose and spin free as my first step. Thanks! -Phillip |
Re: C/30 rear wheels locked up, no fluid
The drums might just be the problem. I had one of mine tighten up, making it pretty much impossible to turn the tire without a lot of force. There's a small gear looking piece at the very bottom of the drum, that will turn both ways. One way to loosen the brake and the other way to tighten it. If it's not a brake, I would take off the rear differential cover and check the gears in there.
![]() Join Date: Oct 2009
Recommend pull the drums and see what's really going on. Both rears locked may indicate a parking brake stuck or something like that.
Had a similar problem once, and could not turn the drum so that the access hole to the adjuster would line up. I cut the rear soft line as close as I could to the "T" and pressurized fluid came out. The line was swollen and would not allow the fluid to return causing them to lock up. A few taps to the drum and it loosened up enough to line up the hole to the adjuster.
If that fails, unbolt the wheel cylinder, giant nut, disconnect the parking brake cables and drill out the shoe retaining nails and pull the whole assembly off |
Get a dead blow hammer and beat (within reason) on the backing plates, shoes might be rusted to the drums. Good luck, and welcome to the forum.
Picked up a dead blow hammer today. I'll get over to the grandparents garage tomorrow and see what happens. Thanks for the advice so far!
Got the drums off today after a lot of elbow grease, beating, and prying. The shoes were really stuck to the drums.. I didn't realize I had to pull the axle shafts out to access the drums. Seems like a kinda crazy design.
I removed the bleeder screws and no fluid came out. ![]() So what are my next steps? What should I look at replacing? I went to Advanced Auto Parts and got prices on some parts. $55 for a master cylinder, $75 for shoes, $10 for a hardware kit that includes all the springs. Should I look at getting all those parts? What about the rubber brake hoses? From this picture of the drum, can anyone tell if its too worn? Does it need to be machined? ![]() Also, can anyone ID the axle I have? ![]() Sorry for so many noob questions. Just trying to learn as much as I can! |
rubber brake hoses - yes
if the brake shop will turn the drums - turn the drums, how they look doesn't matter, the new surface will be correct and concentric - all that matters is if they are thick enough, and the brake shop will measure and tell you if they can be saved. you appear to need a wheel cylinder also if you found that trickle inside the drum when they get to that stage, it's best to replace everything. Sometimes wheel cylinders and drums can be saved, but pretty much everything else should be replaced. |
Fluid in the picture was PB Blaster trying to free the drums. I don't think its the best stuff for brake shoes but I'm replacing them so I wasn't worried.
Curious though why the rear brake lines are dry... |
* VIN/Model Decoders
* Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID Blazer SPID Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Why replace the shoes? Looks like plenty of life left and depending on how old they are may have better linings than today.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
If you notice in the picture, the edges of the shoes got chipped from me trying to pry the drums off them. Are they still fine to use? I don't mind spending a little extra while I have everything off to get new shoes, unless they really aren't needed.
Yes ,the shoes need to be replaced , they are oil soaked and will only cause problems like grabbing , lack of braking.
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
#14 | |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
#15 |
Unless there are cracks in the shoes going through the rivets I personally would not change them. Get you some new cylinders, hoses, hub seals and master cylinder and she will back as new. Clean the shoes and drums really well and sand them with some course grid. Ideally you can get the drums turned but if you can't, don't sweat it. When i replaced my wheel cylinders I think they were like $10 or $17 a pop, you can't beat that.
#16 |
![]() Join Date: Sep 2007
now that everythings off, casn you spin the rearend? im just wondering if the locked up brakes were the problem or if theres something else locking up the rear end
1967custom |
#17 |
Thank you for all the help so far! I'll be getting all new parts, including shoes.
What is a ballpark cost for having two drums turned? And do chain stores do that, like napa, or do I need to find a specialty machine shop/brake place? Michael I still need to check that the rear end spins. But hey if it doesn't, I'll be getting a lesson from you guys in differentials! |
#18 |
My grandparents (who own the truck which I'll be inheriting) have $200 to spend fixing the brakes. Anything above I'll pay for. Guessing I'll be right around that or a little over.
Where do you suggest buying the parts at the best price? I was gonna use Advanced Auto Parts, or are there websites with better prices? It's comforting to be able to walk in with the part to ensure I get the right things. |
#19 |
I buy all my Timken bearings and seals from auto zone .
#20 |
Rock auto was pretty good on brake parts. Even Amazon (prime free shipping) was good on parts too
#21 |
20' Daredevil (Ret)
![]() Join Date: May 2003
Follow the brake lines to see where they go; it's possible the rear reservoir (your empty one) goes to the front brakes. That's how it is on my '72 K20 (with front discs). Not sure about your '70 C30.
I believe the rear diff is an Eaton, which on a C30 should be an HO72. Can you post a front view pic of it?
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
#22 | |
![]() ![]() And where it sits now... ![]() Is it better to put the photo bucket url link in like I've been doing or is there a better way to upload? the attachment button? My pictures seem to be too big |
#23 |
If you do decide to get the parts from Advance be sure to order them on-line for in-store pickup. Right now they have 15% off on-line orders over $50. This is what I do if I need the part right now and can't wait for a possible cheaper option (RockAuto, Amazon, or EBay).
FOUNDING MEMBER OF THE DRUM BRAKE CLUB Second Owner 70 C-10 Second Owner 93 GMC C1500 Third Owner 99 C2500 Crew Cab Short Bed |
#24 |
What are you guys thoughts on replacing vs rebuilding the MC? I'm leaning toward rebuilding to save money.
#25 |
I would replace. They are not that much.
