Old 01-18-2015, 01:44 AM   #1
Monte's62
Valve cover hitting AC bracket
This is a 98 vortec engine, not sure about the bracket. It looks like the correct one, but apparently it's not. Even with the factory valve cover with rounded edges it doesn't work.
My question is, has anyone ran into this problem? Is it the wrong bracket, or do you have to take the bracket off to get the valve cover off. Also, would 3 bolts hold the compressor if I cut this one off? Name:  image.jpg
Monte's62 is offline   Reply With Quote
Old 01-18-2015, 04:15 AM   #2
donthekawguy
donthekawguy's Avatar
Re: Valve cover hitting AC bracket
Doesn't the ac go on the pass. side?
66 shorty
donthekawguy is offline   Reply With Quote
Old 01-18-2015, 08:52 AM   #3
nhr3
nhr3's Avatar
I had a similar issue with my MT valve covers and the air conditioning pump. My Serpentine system puts the pump on the right side but the issue was similar. Fortunately with a little creativity with a grinder the cover and the pump I was able to resolve the interference issue. The serpentine system I used was for a small block from a 1990 Suburban. My AC pump was the one that came with my Vintage Air kit, a Shaden I believe. Your issue looks to be entirely a bracket issue. I would look at grinder modifications.
65 C10 Short bed, Fleetside, small back window
Build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=619304
nhr3 is offline   Reply With Quote
Old 01-19-2015, 12:15 AM   #4
Monte's62
No, the bracket goes on the right (drivers side), and I think this is the one that came off of the engine. I have a couple others that all look the same, and one for sure came off of it. This bracket is a 2 in 1 AC/ power steering bracket. I talked to a good friend today that owns an auto repair shop and he said almost everything that comes in to his shop ( foreign and domestic) has to have some part removed to be able to fix another part. He said he thought it was to discourage businesses like his and do it your selfers from fixing stuff without going to a dealer. This made me think back to my 88 chevy truck, when I remember replacing a thermostat there was a bar running from the housing to the alternator bracket I believe. Needless to say it was removed. I believe this bracket is just made to be moved to remove the valve cover. As mentioned I will just have to do some creative cutting/ grinding I think.
Old 01-20-2015, 02:14 AM   #5
Slow Build
Slow Build's Avatar
They make a few variations. I'm starting to look for a serpentine setup for mine and I've seen the AC on both sides. I'm going to get the AC on the passenger side without air pump and alt on the drivers side with PS pump to make things easier (shorter plumbing and wiring).
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 01-20-2015, 09:09 PM   #6
Monte's62
Slow build, do you know if the engine in the first picture, which has what appears to be the same bracket as mine, will allow the valve cover to come off without moving the AC bracket?
Old 01-19-2015, 02:12 AM   #7
BigDan3131
BigDan3131's Avatar
Are your valve covers taller than stock? If they are that is the problem.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 01-20-2015, 12:02 AM   #8
Monte's62
Yes, they are taller than stock, but the stock valve covers will not fit either. I talked with some guys that tell me that is just how they are made. You have to take the Serpentine belt off and loosen the AC bracket to get the valve cover off. I think I am just going to cut it off and just run 3 bolts. I may look at trimming it up, but I don't think it will work.
Anyone else with a vortec engine and AC have this problem?
Old 01-20-2015, 10:26 AM   #9
luvbowties
luvbowties's Avatar
Smile Re: Valve cover hitting AC bracket
My question is, has anyone ran into this problem? Is it the wrong bracket, or do you have to take the bracket off to get the valve cover off. Also, would 3 bolts hold the compressor if I cut this one off? Attachment 1351008
A friend had the same problem with your engine going into a 1952 Chevy pickup. He had his v-cover modded to fit. The end product depends on how pretty your fabricator can heli-arc weld aluminum. It took a simple cutout--looked like a 1-cut job that required only a flat triangular fill-plate) His end result looked "factory". *BE SURE to allow for rocker clearance!
Sam
luvbowties is offline   Reply With Quote
Old 01-20-2015, 09:20 PM   #10
Monte's62
Sam
Thanks Sam, I might try to modify the ear of the bracket, or maybe even cut it off if necessary. I doubt I will modify my valve covers as welding aluminum may be a touch out of my league. Thanks for the info
Old 01-23-2015, 08:48 AM   #11
luvbowties
luvbowties's Avatar
'tis outta my league too--but that's what friends are for. Also, I would want an experienced heli-arcer to do it in the 1st place, even if the job would be pricey.
Sam
Old 09-20-2021, 07:14 PM   #12
Doppleganger
I know this thread is ancient, but was there ever a bona fide solution to this?
Something with pics would be dandy.
Doppleganger is offline   Reply With Quote
