Old 01-20-2015, 09:45 AM   #1
Seventy468
almost scrap
Seventy468's Avatar
72 4x4 rear frame pic
I am in need of a pic of a rear frame shot of a 72 4x4. Bed on, bed off, whatever is available. I am having to do some repair work (to replace someone else's repair work) to our 72 and would like to know what it looked like from the factory. About 12" of both sides of the rear frame have to be replaced. Im currently having a shop bend me two pieces of 3/16" steel to imitate the frame and then I'll go back and cut appropriate holes, and weld/attach to existing good frame. Any pics would be greatly appreciated.... especially since the "search" function is down.
Thanks in advance.
Seventy468 is offline   Reply With Quote
Old 01-20-2015, 10:31 AM   #2
1972RedNeck
1972RedNeck's Avatar
Re: 72 4x4 rear frame pic
I'll try to get some tonight if I don't forget.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 01-20-2015, 10:34 AM   #3
Ironhorse
Ironhorse's Avatar
I have a '71 long bed 4x4, should be the same. Can get some pics posted later today. Bed is on, have rear mounted poly tank but shoud be able to show what you need. Will pic both left and right sides, inner and outer of frame channel. Need any measurements of hole placement and size or do you have that info?
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 01-20-2015, 01:01 PM   #4
54blackhornet
54blackhornet's Avatar
I have a bare 71 K 10 frame I can shoot, let me know if I can help ?
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 01-20-2015, 04:26 PM   #5
Seventy468
almost scrap
Seventy468's Avatar
You guys are awesome. One side of the frame has all of the holes unmolested so I think I can transfer them ok. I just picked up the bent pieces and hope to make some more progress tomorrow. I am more concerned about what ends were welded on (by PO), and what if any braces were there originally that didn't get transferred type scenarios. Any photos will work, but don't kill yourselves getting them! it'll be later this week/weekend before I get to cut/weld anything on. Thanks guys.
Old 01-20-2015, 04:52 PM   #6
FlameOut
I have a 72 swb 4x4 but my frame is also bad, so I'll be watching this :-)
2004 Chevy Silverado Z71 Ext Cab 1500
1972 Chevy K-10 SOLD
1967 Chevelle SS
FlameOut is offline   Reply With Quote
Old 01-20-2015, 07:54 PM   #7
70'
70''s Avatar
Here is an unmolested 1970 SWB 4x4 frame that I am prepping for restoration.
70' is offline   Reply With Quote
Old 01-20-2015, 07:54 PM   #8
70'
70''s Avatar
Another
Old 01-20-2015, 07:56 PM   #9
70'
70''s Avatar
Frame
Old 01-20-2015, 07:56 PM   #10
70'
70''s Avatar
Cross member
Old 01-20-2015, 11:35 PM   #11
Seventy468
almost scrap
Seventy468's Avatar
70', thanks for those pics... what is your setup? Maybe its because our truck was originally a half ton, but Im almost positive we have 12" of frame past the rear hanger. I will get some photos of what I have in the a.m.
Old 01-20-2015, 11:37 PM   #12
Seventy468
almost scrap
Seventy468's Avatar
Is it possible....I really hope not... but is it possible I have a swb frame that was extended to make a lwb??? Food for thought.
Old 01-20-2015, 11:44 PM   #13
70'
70''s Avatar
Seventy468, the frame in the pic is a 1/2 ton 4x4 SWB.
When it comes to these old trucks, anything is possible. I know there are plenty of LWB's that got cut down to make SWB's so I imagine what you are thinking may be possible has probably been done many times over. I hope that's not the case for though.
Old 01-21-2015, 08:34 AM   #14
Seventy468
almost scrap
Seventy468's Avatar
Here is what I am working with. Frame is upside in the photo. You can see right after the rear most crossmember where someone butted up another piece of frame, or steel and welded it on. We never had an issue with it as far as bumper not lining up or bed not bolted on, but after we got it blasted its become quite the eye soar.
Also attached is what I am working with to replace old stuff. Hopefully today I will be able to punch some holes in the new stuff and get close to being ready to go into surgery.
Old 01-21-2015, 09:16 AM   #15
Ironhorse
Ironhorse's Avatar
Looks like 70' put up some really good pics showing the rear frame channels. Show better than what I could do with the bed installed and a rear tank in the way. Hope the pics help your situation, good luck with it.
Wellington, Ks
Old 01-21-2015, 09:19 AM   #16
Seventy468
almost scrap
Seventy468's Avatar
Thanks, yes they did help... help to show me I might have had a swb frame turned to lwb! lol. I would also be interested in seeing a lwb frame for rebuilding purposes if anyone has one.
Thanks again to everyone.
Old 01-21-2015, 10:01 PM   #17
Seventy468
almost scrap
Seventy468's Avatar
Not exactly sure on how correct the bolt holes are for our actual year but this is how the looked from the spliced pieces.
Old 01-22-2015, 01:24 AM   #18
swamp rat
swamp rat's Avatar
Heres my K20 4X4 if ya still need it:
http://67-72chevytrucks.com/vboard/s...&postcount=200
More here:
http://67-72chevytrucks.com/vboard/s...&postcount=209
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
