01-21-2015, 02:30 PM | #1 |
9" rear end
Has anyone here bought and installed the 9" housing from Speedway Motors for our trucks. It says the housing measures 62" overall with the axles installed. What are your thoughts using this.
Thank you, |
01-21-2015, 03:03 PM | #2 |
Re: 9" rear end
Well, what does your current axle measure?
I've replaced 12-bolts with 9-inch, and one wheel is offset about a half an inch on the 12-bolt, which it won't be with the 9-inch, but GM didn't account for it anyway. Only really matters if you're marginal on tire clearance to begin with. Not sure why this is, though the Ford uses a pinion with a support bearing on its nose, don't think a lack of that'd push it one way or the other.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
01-21-2015, 03:29 PM | #3 | |
Re: 9" rear end
http://www.speedwaymotors.com/Bolt-I...cks,80935.html |
01-22-2015, 12:26 PM | #4 | |
Re: 9" rear end
01-22-2015, 01:37 PM | #5 |
Re: 9" rear end
My 68 truck's rear end measures 62" axle flange to axle flange. I just got a 71 rear end which is 1 1/2" wider so I'd have more wiggle room for rear wheel/tire back spacing. Also it is 5 lug. You can end up with a pretty pricey rear if you go with the 9". You'll have axles, backing plates, brake kit and drums. And a rebuilt center section will run around $500.00. I used a Moser 9" In my last truck, a 49 Ford F1 It ended up being around $1500.00 but that's what I wanted.
I guess the question is why do you want to use a 9"? Are you going to drag race it? |
01-24-2015, 07:04 PM | #6 | |
Re: 9" rear end
If you are looking for a deeper dish look on your rims you will want a narrower rear end not wider. Doing a 9" so when I eventually turn up the boost on the turbo and put in a bigger stall converter I won't have to worry about breaking anything. Not saying I won't but it will be stronger then the 12bolt. |
01-25-2015, 05:07 PM | #7 |
Re: 9" rear end
I don't get it. it is a truck why not use the 14 bolt? Way cheap and bullet proof. If your going full out drag racing, then maybe a 9" .Ford sucks!
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS |
01-27-2015, 01:50 AM | #8 |
Re: 9" rear end
01-27-2015, 07:22 AM | #9 |
Re: 9" rear end
U can get 6 lug hubs for a 14 bolt. If need be you can also get them made to change the wms to wms to a certain extent.
01-27-2015, 01:51 PM | #10 |
Re: 9" rear end
I've got an older mustang 9" rear mocked in a 71 stepside. I considered the Speedway unit, and am curious as to how your project goes.
I haven't torn into my 9" yet and the Speedway unit is still in the back of my mind. |
01-27-2015, 08:28 PM | #11 |
Re: 9" rear end
The 6 lug hubs are 500+ is the only problem .
01-27-2015, 08:32 PM | #12 |
Re: 9" rear end
I found a complete Ford 31 spline 3:50 Traction Lock rear from a 79 f150 for $350. It cost $65 for new axle seats from CPP. $150 to narrow the housing and shorten/respline the axles and redrill the bolt pattern. I had the center section disassembled and cleaned with new bearings for $90. The clutches looked new.
It can be done much cheaper if you're willing to work with some used stuff. I probably could have re-used my driveshaft with a bastard u-joint but I had a new one made for around $200.
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com |
01-27-2015, 08:34 PM | #13 | |
Re: 9" rear end
01-27-2015, 09:57 PM | #14 |
Re: 9" rear end
Check craigslist around your area. That's where I found mine and it was on there for awhile. I was surprised that it hadn't been sold already.
01-27-2015, 10:33 PM | #15 |
Re: 9" rear end
Just curious, and dont get me wrong here but why didn't you look into an explorer rear end?
Factory 31 spline axles, disc brakes, 8.8 ring, 3:55 and 3:73 with factory locker. And if you were planing on cutting a housing down anyway, I think the 8.8 is 56-57"? Also the 8.8 looks just like the twelve bolt on the inside, they already make c clip eliminators for them. Some of the Hot Rod Drag Week cars use this rear end with turbo Ls power plants. Just curious.
I just gotta get out here and do it, why? Cause nobody will do it for me... |
01-29-2015, 04:31 AM | #16 | |
Re: 9" rear end
01-29-2015, 06:12 AM | #17 | |
Re: 9" rear end
Oh, look for the tag on the diff cover, the one you want should come from a v8 with a "L" between the gear ratio... ( 3 L 55 ) ( 3 L 73 ) That means it has a locker.
01-29-2015, 06:26 AM | #18 |
Re: 9" rear end
http://www.hotrod.com/how-to/transmi...ord-rear-axle/
Heres one from hot rod magazine. It says 91-01.
01-29-2015, 06:46 AM | #19 |
Re: 9" rear end
Thank you!I have a 68 step side and im putting a 402 Big block and a 5 speed in cant wait should be a sweet ride .
