01-27-2015, 10:03 PM | #1 |
Roto Reuter thats the name...
71 SWB Chassis w/ engine, trans & drive train; aluminum slots; Vintage Air
I'm selling an original Arizona truck SWB chassis including engine, transmission and driveshaft. The chassis has no rust (only surface) and is in great shape. All mounts including bed, cab and core support are in excellent condition. This is a good opportunity to buy an excellent SWB chassis. Why cut down a LWB frame, when you can have one already set to go? Basically all you need to do is put your sheet metal on this chassis and it's ready to go! Bill of sale only. Aluminum slots extra.
$1500.00 (Paypal, Money Order or Personal Check) I have a trailer and can assist with delivery for an additional cost, to fellow board members, within a reasonable distance. Some details concerning the chassis: Chassis: * Original 71 SWB chassis 5-lug, including engine, transmission & driveshaft * Chassis has front and rear sway bars installed * All fuel lines still on frame and good condition * All brake lines still on frame and connected and in good condition * Front to rear original tail light wiring still installed on frame * Emergency brake still installed and in good working order (I will include the cable that mounts into cab if desired) * All cab, bed and core support mounts in very good condition * Front disc brakes and pads in good condition * Exhaust system in good condition with original exhaust hangers Engine: * 250 cu in engine * Distributor upgraded to HEI * New fuel pump and filter * 6-blade radiator fan * Manual booster * NOTE: Sanden compressor to be removed from engine unless buyer is interested in buying the Vintage Air system that was installed on this truck. Transmission: * 3-speed transmission including shift rods if desired
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
01-27-2015, 10:05 PM | #2 |
Re: 71 SWB Chassis w/ engine, trans & drive train; aluminum slots; Vintage Air
Exhaust is in very good condition with no leaks and appears to be Arizona original.
01-27-2015, 10:11 PM | #3 |
All mounts are in great condition. Even had original ground strap.
01-27-2015, 10:17 PM | #4 |
Engine with HEI, new fuel pump & filter, 6-blade fan, rad hoses, steering gearbox, rag joint & shaft.
01-27-2015, 10:27 PM | #5 |
17" American Racing Ansen Sprint aluminum slots with Goodyear tires.
$800 local pickup. Shipping would probably be very expensive. Wheels/tires: * Rims are 17" American Racing Ansen Sprint Aluminum Slots * Rims are in very good condition with no pitting, just need to be cleaned * Rims are set up for dual BC mounting (5X5 & 5X5-1/2) * Tires are Goodyear Wrangler SR-A, 255/75R17 * Tires are in very good condition with 10/32 tread on all 4-tires
01-27-2015, 10:35 PM | #6 |
Vintage Air System. $500 plus shipping. Don't want to part this out. Everything you see here.
Vintage Air: * Older Vintage Air system, but worked fine in the truck. I will include all parts including the dash control. * Vintage Air evaporator * Condenser with dryer and lines (sorry I forgot to get picture as its still mounted on my core support) * Sanden SD5H14 compressor (currently mounted on engine) * Dash heat and AC controller * VA Glovebox liner * Binary switch (installed in AC line) * Dash vents and connectors (defroster vents were shot) * Blower hoses (one was damaged upon removal, but can be easily replaced)
01-27-2015, 10:37 PM | #7 |
Sanden compressor.
01-27-2015, 11:21 PM | #8 |
dan, nice looking frame! how long can you store this? with deposit of course!
01-27-2015, 11:28 PM | #9 |
I'm sure we can work something out if you're seriously interested. What are your thoughts?
01-28-2015, 07:50 AM | #10 |
Dan, would you do $450.00 on the vintage air?
01-28-2015, 01:28 PM | #11 |
Chassis with engine, transmission and drivetrain sold to Jimer1964 pending receipt of payment. If payment is not received by Feb 4th, chassis will be re-listed. Thanks Jim.
01-28-2015, 10:08 AM | #12 |
Jim, yes I can do $450 + shipping on the Vintage Air. As mentioned above I will have to remove the condenser w/ drier as it's still mounted on the core support. It has the lines that run through the core support as well. Please confirm with "I'll take it" and provide your ZIP and I'll work on getting you shipping costs.
01-28-2015, 10:22 AM | #13 |
Prestige Worldwide
Can you tell me the widths on those Ansens?
01-28-2015, 11:19 AM | #14 |
Good catch. Sorry I should have listed that. They are 17X7 with 4" backspace. Fit very nicely under the truck with no rubbing problems.
01-28-2015, 01:02 PM | #15 | |
Don t ship the condenser, drier, and compresser. I ll have my son pick them up Paypal or PMO?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-28-2015 at 01:12 PM. |
01-28-2015, 01:19 PM | #16 | |
If you're having your son pick up some of these parts, you may want to have him pick up the evaporator too. That is one of the biggest parts. The rest is all small stuff. Either Paypal or MO is fine. If PayPal, we have to abide by forum rules to add to fee.
01-28-2015, 01:25 PM | #17 |
Vintage Air system sold to jaros44sr pending receipt of payment. Thanks Jim.
01-29-2015, 03:12 PM | #18 | |
Sorta like the check is in the mail
01-29-2015, 05:16 PM | #19 |
Looks like Paypal was received. Thanks Jim.
01-28-2015, 01:33 PM | #20 |
American Racing Ansen Sprint wheels with Goodyear tires still available and up for sale.
