01-28-2015, 05:02 PM | #1 |
is it a 348 or 389
With the new to us truck 1959 big window. The body is pretty straight nothing major. Still has 4 speed manual on the floor.
When I looked at the engine the valve covers say Pontiac M/T. The numbers on the block correspond to a early 60 Pontiac 389. Going through the specs on the truck GMC used Pontiac motors and possibly the 389 was downsized to a 348. The motor has a freshly rebuilt appearance and sounds very healthy as if it has a healthy cam in it. So how do i figure it out? |
01-28-2015, 05:44 PM | #2 |
Re: is it a 348 or 389
Definitely not a 348, they call thosw " W " engines. The valve covers are in the shape of a " W "
01-28-2015, 05:49 PM | #3 |
Hollister Road Co.
Its a Pontiac 336 based on the 370. part will interchange. GMC used Pontiac motors back then. some times Buick in the larger trucks
01-28-2015, 08:44 PM | #4 |
If you are really ambitious you can put timing tape on the balancer and use a dial indicator at the rockers to figure out the cam timing and lift, then start looking for ones that are close, or if you are tearing the engine down (does not sound like it) the end of the cam should have an manf grind #.
The valve covers are relatively rare so take care of them. Not a poncho guy so someone else will need to chime in on how to decode the casting or sn stamp on the block.... Every W block engine in a rod is a 409 unless you know how to tell the difference...
01-28-2015, 11:57 PM | #5 |
Now this is funny...and pretty much true.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
02-07-2015, 06:30 PM | #6 |
My brother joked one time years ago that somewhere is a field of many acres covered with Corvettes with the hoods off, front end up in the air from the lack of engine weight because all the "Corvette" 327's are in street rods.
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
02-07-2015, 07:54 PM | #7 |
I read somewhere that there are more 67-70 BB Corvettes on the road today than were produced, many "matching numbers". Very good records exist on the numbers produced, etc. and because of prices lots of incentive to build a fake. Same with Shelby Mustangs...
01-28-2015, 10:08 PM | #8 |
http://www.pontiacsafari.com/MPC/Pages/page_0061.jpg Here's a chart that shows all the 389 engines they built in 1960. Several came with the AFB carb, which yours has. The hipo engines had hot cams, and higher compression. Of course a lot of years have gone by, and anything could have been changed.... Sounds like you have a good one, the Poncho in my '55 runs real strong, and has a hot lumpity cam, and I don't have a clue as to what it is! Enjoy!http://www.pontiacsafari.com/L1Early.../V8%20Engines/ More info on your '60 engine.
'55 Chevy 1/2ton pickup w/ Pontiac 350 and Muncie M21 close ratio 4speed "Red Ryder" Last edited by capnduane; 01-28-2015 at 10:15 PM. |
01-29-2015, 02:22 AM | #9 | |
02-05-2015, 06:18 PM | #10 |
Looks like a ho 389
So here is the numbers.
536387 m-4 Found online a company called butler performance, I gave them the info. According to them it is a 1960 389. Then looking at the charts looked like a 10.75:1 heavy duty. Just missing the tri-power. That said it also came with a 4 barrel carb also. So part of the mystery solved. Thanks for pointing me in the right direction. Last edited by bigwin59; 02-05-2015 at 06:30 PM. |
02-05-2015, 09:22 PM | #11 |
Cool.... Nice hi performance 389, should have loads of torque and bottom end. You scored! Just was over your way, had lunch in Cherry Valley at Flo's. What a beautiful day for a drive thru San Timeteo Cyn. Here's a pic of the Poncho in my '55.
'55 Chevy 1/2ton pickup w/ Pontiac 350 and Muncie M21 close ratio 4speed "Red Ryder" |
02-05-2015, 11:23 PM | #12 |
Not all. Flos is great. The guy who is helping with body work will be over Saturday so I can give him some $. He is going to get the body filler and stuff. Hope to start the work next weekend.
02-07-2015, 06:19 PM | #13 |
Definate poncho
02-07-2015, 06:35 PM | #14 |
Just so everyone knows what a 348-409 looks like.
It's a very cool, distinctive motor. One interesting thing about them is the combustion chamber is in the cylinder and not the head. Check out how the top of the cylinder isn't flat. Brian
02-08-2015, 02:42 PM | #15 |
GMCDAC
It might be possible he meant "347" a Pontiac V-8 introduced in 1957.
DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild! 1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish! 1955 GMC 100 2nd design driven almost daily! Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09 GMC driver for 30 years! |
