Who Me?
Baggin the front of a 61
Do any of you guys have pics of the LCA and how you made lower bag mounts for them?
It looks like 64-66 upper bag plate will work just fine on the 61. Thanks!
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Re: Baggin the front of a 61
Member joe dirt posted some pics of how he done his last week.
pics are on my phone...its simple,..plate the bottom of the arms and mount the bags to to plate...I didn't use upper mount plates,..the 61 already has plate up there due to no coil springs...ill post pics later from my phone
Who Me?
Cool! Thanks Joe Dirt!!
Heres the plate on the bottom arm....and i just mounted the top right on the stock upper part of the xmember
You can kinda see the access hole i made in the front portion of the xmember to get the bolts in the bag
Who Me?
Great pics.. So that upper area is flat to mount the bag? I thought it had a curve to it.. The access hole is a great idea too..
What size bags did you use? 2500# or 2600# and are they 7" round? Looks like you have plenty of clearance on the sides. When you removed the torsion bars, do they just slide out of the control arms? Did you keep the torsion bar cross-member or remove it?
upper area is flat enough to mount the bags,..just got to get the positioning just right so your bolt holes are on solid steel and the fitting ends up in the open area..its a bit tricky,..i used 2600 bags in front 8" round...had to clearance the arms a bit to make room...my pics show some of that clearance
also,..for the torsions,...had to torch them off then press out the rest,,,all of it was removed
Who Me?
Thanks Joe!! I appreciate the pics and tips!
