67 Suburban Diesel Conversion Ideas
Just in the dreaming phase right now. I'm still looking for a 67 Suburban to buy. It will happen sometime this year or the next though. I would like to get the opinion of some of the more experienced members if you have the time to respond.
1. What would be the best diesel/auto trans combo if MPG is the most important factor? 2. Is it possible to get over 25mpg with the right setup? This would be a daily driver that would rarely be towing anything. I'm sure I will have a 100 more questions once I find my Burb and get started. Thanks for your time. Last edited by Adam Moyers; 01-29-2015 at 09:46 PM. |
Re: 67 Suburban Diesle Conversion Ideas
6.2/6.5 for mileage they run good if you fix the common problems. It will bolt right in use an overdrive trans the th400 isn't the best for mileage.
1976 k20, 350 built, 44/14 axles 1968 c10 6.5 turbo diesel,t5 trans 1977 gmc c3500 dually, crew, 4-53t, 5&3 trans http://67-72chevytrucks.com/vboard/s...d.php?t=591188 |
6.2 would be the easiest swap. i dont think you will see mid twenties with it, but i bet you could set it up to do well, assuming a lower 2wd truck. there are claims on the web of 4bt fullsize trucks getting mid twenties. i bet if you set it up specifically for mileage and not hot rodding or big power its doable with a 4bt. lifted 4x4s are going to get worse mileage. for the 6.2 i agree a 700r4 would likely do the trick. with a b series cummins you can pick from many. dodge, gm, ford etc. they are adaptable to most popular stuff.
Thanks for the replies. Would it be possible to get 25+ with a newer ecodiesel?
1/2 or 3/4 suburban? an honest 25mpg is pushing it, with any fullsize truck.
4/6bt would be my go to. The 6.2/6.5 might be easier swap wise, but I personally hate 'em. Unless you can get a 6.2/6.5 DIRT cheap its not worth the hassle. |
I dont have one yet, but I won't have a preference when I find the right one. Thanks for the input.
I have a 97 Chevy K3500 ( 1 ton 4wd) crew cab dually. It has the 6.5 in it. When driving easy and no load I can get 24-25 mpg range. Loaded or drive hard and likely will see 18-19 mpg.
6>8 Plugless........
![]() Join Date: Sep 2007
We've worked on 2 different 97-98 chevy 2500 extended cab long bed 4x4 trucks that had p-pump 4bt's in them. They both got 25-28mpg driving hwy and 20-22 in town. Pretty hard to beat IMO. It really depends what you want. A 4bt will require mods, the 6.2 or 6.5 will be a bolt in deal for the most part. Also, how much you want to spend will affect this too.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
Nice to hear of a few getting around 25mpg. Since this is the dreaming phase, the cost doesn't really play a role to me right now. This is how I look at it, people are spending $60-70k on a new suburban that will be worth nothing in 10 years. I would rather put $40-50k in a 67 and have it forever or at least be able to recoup some of the money spent if I needed to sell it.
This thread could easily turn into a 67 C10 truck or 69-72 blazer thread if the right opportunity presents itself. I've got my eye on a a 67 truck thats only 30 miles from home. Thanks again for the input. |
