01-30-2015, 04:12 PM | #1 |
Important Rust/Screw Question..
I've noticed on some of the screws that I have removed, such as the kick-panel and drip-rail screws, there is a hard amber-colored rubber/wax coating involved.
Being very rust-paranoid, I'd like to ask just what this coating is, where do get it, and how is it properly applied. I assume it is some kind of coating to help keep the threading of the socket from corrosion? A lot of these screws go straight through the body metal. It would suck to go through a lot of hard work restoring something, only to have rust start growing right from a corner, hole or socket because it wasn't fastened or sealed right. What's the proper procedure for drilling/screwing?? Thank you. Sincerely, IdahoMan |
02-03-2015, 12:23 AM | #2 |
Re: Important Rust/Screw Question..
Anyone?
02-03-2015, 01:18 AM | #3 |
Hey, pard - I don't have a definitive answer to your question, but I figure us Idaho guys got to stick together so here's what I think may be the case:
Check out this old GM video on YouTube that describes how the 1979 Suburbans were built: https://www.youtube.com/watch?v=SgDK6LVyUmI#t=130 I set the link to the correct part of the video where they show a GM line worker spraying what the narrator says is an "aluminum wax preservative" on the inside of a door panel. Although the color isn't exactly the same as what is shown in your picture, I still think that is the stuff that comes off of certain interior screws. I've noticed it myself many times as well, and until I saw this video I was never sure of the cause. I've never added any additional goop when replacing such screws, but maybe I should have. I look forward to hearing others chime in on this.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205 |
02-03-2015, 04:44 PM | #4 | ||
As you might know I started at the Flint Truck plant (the only plant building Suburbans at that time) in June of 1979. Quote:
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
02-03-2015, 05:43 PM | #5 |
02-13-2015, 07:30 PM | #6 |
BUMP for answers.
Rust and cancer are two things you never want to deal with. |
02-03-2015, 11:59 AM | #7 |
That was my guess, some kind of rust proofing inside the body either aftermarket or factory. I don't recall it in my trucks but other GM cars I have worked on had a reddish brown coating inside some body panels. You would have to be creative to reapply it in those areas that are no longer accessible.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
02-03-2015, 04:19 PM | #8 |
When I removed my drip-rails, the screw's tips had been dipped in some kind of amber colored rubber/wax.
