Old 02-01-2015, 01:05 PM   #1
68_Step
Finding TDC
I am getting ready to rebuild my distributor on my 1978 K30 454ci and I want to verify TDC before putting the distributor back in. I made the below list, using several threads I found on the forum. Does everything look right? If something is out of order or wrong point me in the right direction.
One thing I am still fuzzy about is how far into the cylinder i screw the stop.
1. Insert the piston stop, then turn the engine by hand until the piston contacts the stop. Mark the balancer at that point where the 0* is.
2. Then rotate the engine back the opposite way until it hits the stop again. Mark the place where it stops using the 0* as a reference
3. TDC is exactly between the marks. If that is where the factory timing mark hits, nothing needs to be done. If it dosn't make a new "permanent" mark.
4. Rotate the engine to where the the harmonic balancer is lined up on 8 degrees to the right of the 0*
5. Holding the dist above the hole, point the rotor to the #1 piston and drop the dizzy in. May need to turn the oil pump shaft.
6. If the rotor rotates away from the #1, pull and adjust, drop in again. Adjust oil pump shaft again if needed.
7. Install the dist cap, whichever tower the rotor is pointing at is now #1 - should be front right corner
8. Install the plug wires in firing order sequence: 1 8 4 3 6 5 7 2 working clockwise around the cap
9. Cut wires to fit and istall the plug wires to the plugs.
So other than hope I don't goof it up, does the list look OK? Thanks guys!
68_Step is offline   Reply With Quote
Old 02-01-2015, 01:18 PM   #2
enaberif
Re: Finding TDC
TDC #1 = #3 intake valve all the way open
enaberif is offline   Reply With Quote
Old 02-01-2015, 01:38 PM   #3
rich weyand
rich weyand's Avatar
Re: Finding TDC
No, it's not OK. How do you know WHICH top dead center you are on, the one between compression and power strokes, or the one between exhaust and intake strokes? Since the crankshaft rotates twice for every rotation of the camshaft, the same crankshaft position could be correct, or could be 180 degrees out on the distributor.
The correct TDC is when the valves on #1 are both closed.
Another way to check it is to pull the plug and mechanically turn the engine over with your thumb on the spark plug hole. The correct TDC will push your thumb off the hole.
BTW, for making the timing mark, it doesn't matter which TDC you use. The timing mark goes past twice every distributor rotation.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 02-01-2015, 04:31 PM   #4
Pampas56
Re: Finding TDC
Rich:
See previous post.
You are correct in that both valves are closed both times #1 hits top dead center. the difference is the intake valve that is open on another cylinder.
#3 is open on #1s firing stroke and #2 is open on intake stroke.
In the old days if it wouldn't fire on startup, we would pull the distributor and rotate it 180 or just rotate the plug wires and time with #6
1989 Silverado K2500ECLB- 307K miles with 90 K TBI 350-Not a show truck, a work tool that I can drive!
1992 K1500 ECSB- 190K miles- I guess I'm just a truck guy now!
Pampas56 is offline   Reply With Quote
Old 02-01-2015, 08:11 PM   #5
68_Step
Re: Finding TDC
Originally Posted by rich weyand View Post
No, it's not OK.
I forgot to start that list making sure I am on the compression stroke. If I do that, is the checklist OK then?
BTW, this is a good discussion - I have learned a lot.
Old 02-01-2015, 11:36 PM   #6
rich weyand
Re: Finding TDC
That'll do it.
Rich Weyand
1978 K10 RCSB DD.
Old 02-01-2015, 04:46 PM   #7
rich weyand
Re: Finding TDC
No, the valves are both completely closed when #1 hits TDC between the compression and the power stroke. Both valves are partially open at TDC between the exhaust and intake stroke.
The exhaust usually closes 10-20 degrees after TDC, while the intake usually opens 10-20 degrees before TDC.
That's why the "push your thumb off the spark plug hole" test works. Another test for the correct (ignition) TDC is to put an air hose into the plug hole with a rag around it and hit the air. If the rag blows out, it is the ignition TDC. On the wrong one, the air will blow through the (partially open) valves.
Another test is to move the engine either way from TDC. If the valves on #1 stay still, that's ignition TDC. If the rockers move, that's the wrong TDC.
In any case, the OP didn't say anything about determining which TDC he was on before stabbing the distributor, and that gives you a 50/50 chance of being wrong. Murphy's Law says it's actually more like 80/20.
Rich Weyand
1978 K10 RCSB DD.
Old 02-01-2015, 05:02 PM   #8
Pampas56
Re: Finding TDC
I understand.
The valves are just beginning to open and close. Too subtle a difference for my old eyes. The easier way to tell is to look for the proper wider open valve on #1s firing stroke.
An alternate method is to watch the valves on #1 as you rotate. As soon as #1s exhaust valve opens wide you should be on the exhaust stroke. one full rotation should close that valve and bring you up on the TDC for the power stroke.
An old mechanic told me years ago that the valves should be closed or close to it near TDC or you end up with bent valves.
Good discussion.
Old 02-01-2015, 06:13 PM   #9
Bigstevex4
Bigstevex4's Avatar
Re: Finding TDC
Or just take note of were the rotor is when pull the distributer and put it back in the same spot. Even if your off a tooth you can compensate for it. Forget about top dead center.
Bigstevex4 is offline   Reply With Quote
Old 02-01-2015, 08:07 PM   #10
68_Step
Re: Finding TDC
I don't want assume the PO had it in the right spot to begin start. I have the time right now so I figured I would learn how to find TDC to set the timing from scratch.
Old 02-09-2015, 02:18 AM   #11
cmax87v3500
cmax87v3500's Avatar
Re: Finding TDC
put your finger in the #1 spark plug hole, have a friend rotate the engine until you forcefully feel air moving past your finger go until it stops and you should be close.
1987 GMC V3500 Sierra Classic
cmax87v3500 is offline   Reply With Quote
