02-02-2015, 06:50 AM | #1 |
Has anyone used these subs before?
I don't have a lotta room under my new bucket seats since I put in procar pro-90s and bracket in. I'm kinda tall, so I had to cut the seat bracket down, leaving me with little room for subs. I know the best way is move the gas tank, but I don't have the time for that anytime soon.
http://www.retrosound.com/product-p/hot-sub-8100.htm
Josh 72 C10, 350/2004r, Porter Steel Pacs, and 40+ years of leftovers from strange POs... |
02-02-2015, 12:53 PM | #2 |
Re: Has anyone used these subs before?
I have not had experience with that exact one, but similar designs I have seen sound horrible. It does have decent reviews on Crutchfield. http://www.crutchfield.com/p_068SUB8...er-reviews-tab
I have tested out one by Alpine and one by Kicker in the past, and they were both pretty sad sounding. I have the same seats and frame as you, and I lowered mine as far as it would go. The front of the bracket sits on the hump. I'm not certain that would even fit under my seats. I built my sub into my center console.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
02-02-2015, 02:30 PM | #3 |
US Army Veteran
I haven't tried their specific "brand," but I can tell you that if you are looking for "decent" bass to compliment a system, you can fit a Bazooka 8" tube in the passenger corner area behind the seat. It's a tight fit in that corner, but gives off some really nice bass to compliment a system.
Kenwood and Kicker also make low profile, powered subs, that will fit under the seat. They all really bring out the overall bass in a system to round it out.
1972 C10 Highlander - The making of a daily driver |
02-03-2015, 01:22 AM | #4 |
Lattimer I like how you did yours. I was trying to think of a way to do that, but I didn't even think of using 2x4s. So simple. Where did you get your console? Looks so much better than then LMC one I have
Those bass tubes are cool, I've never seen them before. Does it sound weird having just one sub in the one corner?
02-04-2015, 09:25 AM | #5 | |
I cut the strap off and screwed it to the subwoofer box, then spaced the box up with the 2x4's and screwed them to the frame. I've used the bass tubes before. They create bass, and some of them can create a lot. They are not real accurate on sound, so if you are a particular person when it comes to sound, you won't like them. They tend to be muddy compared to a regular sub enclosure. The position of the bass in the vehicle should be a non issue. The way the low frequency waves move through air, the bass will be "enveloping" you in the airspace in the cab regardless of where its located. Speaker position means a lot more the higher the frequency. Put tweeters in the wrong place and they are useless.
02-04-2015, 02:48 AM | #6 |
hijack...im putting the pro-90 lobacks seats in my 86 in the near future. you have any pics?
02-04-2015, 02:59 AM | #7 |
This is the only one I had. I can take more in the morning if you'd like. I have the velour ones, they're very comfortable. The main reason I wanted these was for the head protection, and they work well. The only complaint I have, and I think Lattimer can agree, is that the seat bracket that goes with the seats is way to tall. I'm 6'3", and my head hit the roof, so I had to get about 2.5in taken out. I would suggest making your own brackets if you have the tools (I do not) even if you are on the shorter side
02-04-2015, 09:33 AM | #8 | |
Mine are the black vinyl seats.
02-06-2015, 02:45 PM | #9 |
Man that is one beautiful interior. I love the paint being gone where the arm hangs out the window. Love some more pics if it's not too much trouble.
02-06-2015, 04:43 PM | #10 | |
I was originally going to paint the doors, and the whole truck for that matter. Somewhere along the way the cost of doing a full rest seemed like way too much, and it turned into a shop truck. Now the worn areas "fit" perfect, and I like the historic look of it.
02-04-2015, 03:00 AM | #11 |
Also, ignore the holes in the door panels and too short carpet. PO, not me haha
02-08-2015, 05:40 AM | #12 |
Well I went with the 8" bazooka tube BruthaMan suggested. I bridged my alpine amp so the sub is using two channels and it sounds real good and hits hard. 100x better than those POS custom autosound ones I had before. It is a bit muddy and not a clear as a real sub and enclosure like Lattimer said, but I think having a good amp helps a lot. Anyways, these trucks are loud and its not like I can tell its a little distorted when I'm on the freeway with the windows down.
Thanks for the tip, never would have considered putting one of these in it!
02-08-2015, 11:50 AM | #13 | |
03-06-2015, 12:51 PM | #14 |
03-06-2015, 12:50 PM | #15 | |
We do have our unique Flat subwoofers also that are designed to fit in small sealed enclosures so that can be placed behind the seats. Those will provide a better bass sound for those looking for that.
RetroSound...Modern Sound for your classic |
