02-04-2015, 12:10 AM | #1 |
1972-4x4 light
Recently bought a GMC K1500.I would like to have some kind of light showing when in 4x4,has anyone rigged one up?
02-04-2015, 08:44 PM | #2 |
Re: 1972-4x4 light
Late model NP205s had a switch in the outer detent spring/ball setup rather than just a plug, spring and ball. You may be able to still find one for an 86+ 1-ton, maybe others.
Google says GM P/N 15594176 https://www.google.com/?gws_rd=ssl#q...+detent+switch |
02-04-2015, 09:33 PM | #3 |
Re: 1972-4x4 light
Thank's franken.
02-05-2015, 10:03 AM | #4 |
Re: 1972-4x4 light
I have a light in my head
02-05-2015, 06:30 PM | #5 |
Re: 1972-4x4 light
205's are usually loud enough when in 4x4 that you have no problem knowing... And on mine, the bumpsteer will clue you in pretty quick!
02-06-2015, 12:12 PM | #6 |
Re: 1972-4x4 light
Mine makes no noise at all when in 4x4. You usually find out when trying to turn a corner
71 K20 64 GMC mud truck |
02-05-2015, 08:31 PM | #7 |
Re: 1972-4x4 light
Why do you get more bump steer in 4WD?
1973 C20, 350/350 |
02-05-2015, 11:43 PM | #8 |
Re: 1972-4x4 light
Just go around the corner in 4x, you'll understand.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
02-06-2015, 08:08 AM | #9 |
Re: 1972-4x4 light
Because, in these 4x4's, the drag link moves in an arc as the suspension goes up and down. Since it's connected to the steering box it moves the steering wheel back and forth
02-06-2015, 04:22 PM | #10 |
Re: 1972-4x4 light
Mike C claims that you can tell by the bump steer whether or not it's in 4WD. I understand why there's bump steer, just not why being in 4WD would change it.
1973 C20, 350/350 |
02-07-2015, 09:36 AM | #11 |
Re: 1972-4x4 light
I guess he's saying you can't help but notice when 4wd is engaged by the many ways you feel the difference of the front wheels being engaged. I guess the most likely time you'll be in 4wd when you didn't intend to is when it was left in the last time you drove. It doesn't take long to notice, if roads are clear. I routinely put it back in 2HI before I get out. I often need 4wd just to back up my driveway. Even in my '92 with a graphic display on the console I would pull out and wonder why the truck felt funny, then look down at graphic and DOH! Never got far w/o realizing.
02-06-2015, 01:53 PM | #12 |
Re: 1972-4x4 light
Search for this in 67-72 Tech Tips "67-72 New use for the empty slot in a tach cluster"
An interesting lighting option to your idea. Bruce |
02-09-2015, 05:34 PM | #13 |
Re: 1972-4x4 light
Search is completely busted because nobody tipped their server.... (Migrating to a new server)
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed |
02-09-2015, 09:54 PM | #14 | |
Vintage 4x4s
Re: 1972-4x4 light
I like it.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
02-06-2015, 03:19 PM | #15 |
Re: 1972-4x4 light
Too bad the only switch I can find is $100. Maybe I should look at a Dodge application. Did they have a light?
02-06-2015, 05:54 PM | #16 |
Re: 1972-4x4 light
Sorry I mis understood
02-07-2015, 08:43 PM | #17 |
Re: 1972-4x4 light
Heh, I didn't check the switch price. $100 would hurt.
A cheaper route might be a weatherproof limit switch on the shift linkage. |
02-10-2015, 11:01 AM | #18 |
Re: 1972-4x4 light
Yeah, it's pretty difficult to drive for any length of time in 4WD without knowing it. Everything feels different.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED |
