Old 02-04-2015, 01:41 PM   #1
brwn70gmc
99 454 rough idle
My 1999 454 suburban idles poorly, it nearly dies sometimes but recovers.
It runs great at startup, cold, but after about 30 minutes, idles rough.
It has 175,000 miles on it,1000 miles on intake gasket job, hoped that would the fix rough idle. New fuel filter didn't help. I think it may need injector replacement or maybe a knock sensor. No I haven't pulled a code yet...
brwn70gmc is offline   Reply With Quote
Old 02-04-2015, 02:47 PM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: 99 454 rough idle
IS the check engine lamp on? That would be the first step.
Could be an IAC problem. It could be sticking or gummed up. How did the throttle body look? All gummed up with crud?
The biggest problem with the injectors on these is they leak after the truck is shut off. Usually it will be hard to start and have a pretty decent misfire until all the excess fuel is burnt off. The FPR leaks too.
Both of my vortec 454s idle fairly low, about 425 at normal operating temp, but its nice and smooth.
95 S_Trucker is offline   Reply With Quote
Old 02-05-2015, 03:58 PM   #3
brwn70gmc
no check engine light, throttle body was cleaned out well during intake gasket rebuild. Mine idles warm about 5-600, but seems to "stumble" and nearly dies, like an old Quadrajet with a bad filter. Fuel filter is new.
If injectors leak overnight and it runs well cold..hmm. It almost feels like a fuel PSI issue at warm idle.
Old 02-10-2015, 01:00 PM   #4
83GMCK2500
Sounds like you need to test the fuel pressure as well. Need to test with key on engine off and key on engine running, the latter preferably with it hot to duplicate your poor idle condition.
Also, I see this thread and your tensioner thread are in the wrong areas of the forum. The more correct area is the one prior to this one. Your '99 Suburban is still the GMT-400 platform which technically ran to 2002, the years are really general guidelines. I always suggest that people post within their bodystyle of vehicle.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
rough idle
